seized spark plugs
Old Jan 29, 2023 | 04:33 PM
  #31
rensoyka's Avatar
rensoyka
Originally Posted by RennListUser01
Pretty easy to keep it clean while removing, and lots of suction from a specialty vacuum would be appropriate ... then scope it to see what's in there?
Head removal seems a bit extreme (does engine need to come out?) ... this can't have been the first time this has happened.
If you can be sure that every bit of the guts of the plug are clear then an extractor should work. Even a small piece left in the cylinder will destroy it. You also have the issue of wrecking the threads in the plug hole while wrenching the stud out. For a high performance engine l would be pulling the head and heating it from inside first, expand the head threads and the stud comes out.
Old Jan 29, 2023 | 05:16 PM
  #32
RennListUser01's Avatar
RennListUser01
rensoyka,
I've read dozens of write-ups of folks who broke their plugs while removing - many had residue in the cylinder - and, lots of input from mechanics who believe small bits of debris will be blown out nearly instantly. Lots of advice to ensure one scopes the cylinder - and, equipment to do this is pretty common.
In general goes like this:
- break plug
- remove parts still in the plug well
- if the ceramic is still in the remaining part of the plug, use one of the devices to break the ceramic then remove remainder with extractor device (various types)
- if ceramic came out with the top of the plug, use extractor device to remove threaded portion of the plug
- vacuum the cylinder out ...
- scope to see what might still be in there
- use a flexible device with adhesive - or even heavy grease per one fellow - and swap the cylinder out
- rescope
I would need to exhaust all these steps, first - perhaps even get a mechanic involved who professes a knowledge of having done this before.
Old Jan 29, 2023 | 05:40 PM
  #33
rensoyka's Avatar
rensoyka
There is a good chance that these methods will be successful. It all depends on your tolerance for risk. I have to wonder what a porsche factory mechanic would recommend. This is my first 911, spent the past 40 years fixing and modding lesser cars but no more. I'm 66 and I can afford the pros to keep it as new so I have no tolerance for risk anymore.
Old Jan 29, 2023 | 06:07 PM
  #34
HardRider's Avatar
HardRider
After plug is removed, use vacuum to suck out. Then use compressed air to bow out cylinder, anything left will be blown into the exhaust or out spark plug hole.
Old Jan 29, 2023 | 06:34 PM
  #35
raaizin's Avatar
raaizin
Was the engine hot or cold. I believe they should come out on a cold engine. Did you try when engine was cold?
Old Jan 29, 2023 | 06:38 PM
  #36
RennListUser01
Ho Boy - lots of threads with lots of threads ... :-)
https://rennlist.com/forums/928-foru...threads-2.html
Old Jan 29, 2023 | 07:07 PM
  #37
F1SML8R's Avatar
F1SML8R
Originally Posted by Revsportz
Props for having 142k miles on the 991.2
Definitely thumbs up for driving it, but thumbs down for the crappy maintenance. First owner allowed it to go 3 x's the mileage to 90K and then the second owner let it go to 142K almost double the cycle the second time around. Yeah, you might have a problem or two.
Old Jan 29, 2023 | 09:11 PM
  #38
HardRider's Avatar
HardRider
what value does this statement have regarding remediating the current situation? Insanity replacing plugs every 4 years, most have 100K miles limits. Guess Porsche is feeble vs Toyota, Nissan, GM, ford, Mazda...
Old Jan 29, 2023 | 09:20 PM
  #39
pdxmotorhead's Avatar
pdxmotorhead
I can't see extracting the plug without dropping the motor.
getting at them is a challenge when stuff is going right..
where it broke off it also likely dropped the ceramic bits and guts in the cylinder.
Motor out on a stand there is a chance you could get the broken plug out, by turning the
motor sideways so any lube you spray in the hole gets to the threads and you can let it soak.
Dont run the motor. if it broke the ceramic off in the motor it will destroy stuff if rotated.
Old Jan 29, 2023 | 09:26 PM
  #40
RennListUser01
pdxmotorhead,
Sure, but you're saying there isn't enough access to suction out the cylinder and check it with a scope?
Old Jan 29, 2023 | 09:31 PM
  #41
asellus's Avatar
asellus
Originally Posted by HardRider
Bewildering why everyone keeps interating the change interval. How does that help remove the broken plug? I pretty sure a local Porsche shop/mechanic has seen this before and can remove. Easy enough to get an extractor in the broken plug, I imagine with the right amount of heat it will come right out. Oh yea you should change them more frequent.....
The going rhetoric for many members here is that porsche recommends the short change interval as some kind of money grab, and that they as individuals simply know better and opt to go for 100k miles or whatever insanity.
With an example of this happening, the other side will be quick to point out "yeah, that's what the interval is for." This thread was practically over with the second post, redirecting the OP to the appropriate thread, where I hope he found a good shop.
Old Jan 29, 2023 | 09:46 PM
  #42
RennListUser01
Well, sure - practically.
Old Jan 30, 2023 | 12:28 AM
  #43
asellus's Avatar
asellus
Well-wishes, scolding, and pissing matches about maintenance habits aside, of course.
Old Jan 30, 2023 | 02:52 AM
  #44
IXLR8's Avatar
IXLR8
I just removed my factory installed spark plugs this past summer, 7 years after Porsche AG installed them. I cleaned the threads and applied a thin coat of anti-seize as I have been doing for the last 40+ years on all my motorcycles and cars (yes, I know about the NGK recommendation). Never an issue, even on high mileage daily drivers.
I then torqued them to the minimum specified torque setting using a quality and calibrated Snap-On torque wrench.
Question is, how did they seize due to rust? The ignition sticks have a very good rubber seal.
This might be tough to do it right.
Old Jan 30, 2023 | 02:58 AM
  #45
IXLR8's Avatar
IXLR8
As long as the insulator stayed intact with a clean break, the ground electrodes should retain the insulator. I have no idea how the 991.2 end looks like.
I feel for the owner. I bit of finesse might have helped.
