Rear axle steering
Old Jan 22, 2023 | 08:58 AM
GilMGTS's Avatar
GilMGTS
Default Rear axle steering
How substantial is it for handling? Not concerned about parallel parking, more so feel around the Twisties.
(Apologies if this is an exhausted topic, I tried to search it and came up with nothing)
Old Jan 22, 2023 | 09:10 AM
S S's Avatar
S S
It gets discussed a lot. But it comes down to what you want….
For me, it totally makes the car better. More stable at speed, more planted, more agile and confidence inspiring. Some people don’t like the ‘artificiality’ of the feel. You will definitely feel it adjusting the rear end at times, and that is what it’s supposed to do. I also appreciate the smaller radius slow speed turns.
For me, very glad I have it and prefer it. I’ve never felt that I’m missing out on ‘classic 911’ handling with it, and can still get plenty of rear end slip when I want to.
Good luck!
ß
Old Jan 22, 2023 | 09:16 AM
GilMGTS's Avatar
GilMGTS
[QUOTE=S S;18586139]It gets discussed a lot. But it comes down to what you want….
Good luck!
So in essence if you did not have it you would miss it.
Thank you for the feedback
Old Jan 22, 2023 | 10:23 AM
Zylinderkopfdichtung's Avatar
When I decided to buy a 991 I drove cars with and without RAS. I immediately felt the difference and much preferred the ones with RAS. To me, it makes the car feel much smaller. It makes the 991 feel almost Cayman-like, or like older, smaller 911s but without the detriment of the engine behind the rear axle.
Old Jan 22, 2023 | 10:30 AM
GilMGTS's Avatar
GilMGTS
That's huge!! I currently own a 718 GTS (2.5) and love how she handles. She's quick but not rocket fast like the 911's. I was hesitant to make the move because of the lost and handling feel. I think RAS would play a very big role for me.
Old Jan 22, 2023 | 10:54 AM
CarlosCA's Avatar
CarlosCA
I can't comment on "without" but will say that yes my 991.2 Carrera S feels a lot on track like my 2002 996 with sport suspension (030), very "light" on track and 100% responsive to driver input. Credit to Porsche engineers for making a ~3200lb car feel lighter than it is.
Old Jan 22, 2023 | 11:37 AM
S S's Avatar
S S
Old Jan 22, 2023 | 11:38 AM
S S's Avatar
S S
Yes. Since you appear to be contemplating moving from the Cayman, as I did, you will definitely appreciate RAS. It will pretty much insure you don't miss your Cayman at all, in fact. Other than a slightly larger cabin feel, the car will definitely feel just as small on the road, as pointed out above.
Old Jan 22, 2023 | 12:52 PM
DC911S's Avatar
DC911S
I have it on my 2019 C4S and like it. I sort of had to calibrate my brain to realize it’s going to turn quicker than a car that size normally would. Long ago and far away my 300Z Twin Turbo had a similar but cruder system as well. I think Honda Prelude Type S, long ago and far away, had it too.
Old Jan 22, 2023 | 05:32 PM
MingusDew's Avatar
MingusDew
Veteran: Army
911 CUP cars don’t have it, so apparently some people are okay without it.
Old Jan 22, 2023 | 06:22 PM
GilMGTS's Avatar
GilMGTS
Good to know 👍🏼
Old Jan 22, 2023 | 06:54 PM
Lee Rambler's Avatar
Lee Rambler
mitsu 3000gt vr4 / dodge stealth r/t twins had it, so did the misty galant vr4. Aome Ferrari gt’s do, though don’t know if any of their track focused cars that do. I know at one point it was discussed for corvettes though I don’t believe it ever hit production. There are probably more examples too, but can’t think of any.
oeraonally it sounds to me like something else to break and need bushings etc replaced….
Old Jan 22, 2023 | 07:47 PM
2-Rotor's Avatar
2-Rotor
All 991 GT3 cars have rear axle steering standard. I am pretty sure the 992 GT3 has it as well. It was optional on the 991.2 and 992 carreras.
Old Jan 23, 2023 | 08:45 AM
detansinn's Avatar
detansinn
You can't go wrong either way...
A car without RAS delivers a classic 911 driving experience like its forebears. The GT3 Cup cars don't have RAS.
A RAS equipped 911 turns quicker/sharper. It does give up just a little rear end feel compared to a non-RAS car. It's a fair compromise, but a compromise nonetheless.
The thing that people forget to tell you about... most RAS 911s are equipped with Porsche's Lithium battery which provides more consistent voltage over the battery's state of charge. Replacement costs of the Porsche Lithium battery are not inconsequential and there's no easy path for retrofit given how it connects to the car. It's not going to bankrupt anyone buying a 911, but the replacement cost is about 5-10x the standard battery cost. Not a negative per se, but an important FYI.
Old Jan 23, 2023 | 08:51 AM
DC911S's Avatar
DC911S
I have no idea if I have a Lithium battery. It’s not listed on my build sheet. Now I’m curious.
