Water pump leak?
External leak is not the main problem. It’s an internal leak sucking coolant into engine. Porsche revised water pump to not circulate when cold to warm engine faster. They do this with a vacuum modulated shield. If pump leaks internally then engine vacuum pulls coolant into engine. Get it replaced or have dealer sign letter the dealer and Porsche assume all responsibility for engine damage and premature wear. You will be leaving desire in loaner as they replace water pump
I’ve just been told. "There is no active leak at this time; what the customer is seeing is residual coolant coming out of the weep hole at a temporary time of over-pressure, which is acceptable by Porsche specs."
Not having one of these .2 overly-complex vehicles, I am curious as to what is the fail-safe mode should the vacuum hose become disconnected or the vacuum valve relay becoming U/S. Lets hope the fail-safe mode is for normal "run" operation and not the short "warm-up" cycle.
Fails open so no vacuum and its like the old 991.1 pumps
Quick update. Had a second dealer take a look at it for my peace of mind and they said the same thing, no active leak. Also, wiped off the residue and have checked over the last few weeks and i don't see any new build up. Got my fingers crossed on this one!
Another update. I had my car in for service at an Indy and he said there was definitely a coolant leak from the water pump. He had to add almost a full bottle to get it to max. Drove it for a while and indeed the coolant level did drop despite no signs of an external leak. Made an appointment with the dealer and they confirmed an internal leak and they will replace the pump and a few associated parts under warranty. Just thought I'd share for others who suspect a leak but don't see an obvious external leak.
Also they tested my original 7 year old battery and found it to be bad. I was quoted just over $1000 to replace it! Absolutely insane! I told them I will DIY that one.
