sudden usb death
Old Jan 3, 2023 | 11:27 AM
asellus's Avatar
asellus
good info! keep us posted -- unfortunately I'm tapped out here, you're referencing the same documentation I would be.
Old Jan 3, 2023 | 12:26 PM
xploits's Avatar
xploits
What a coincidence! I'm busy with work, so I'm going to test it tomorrow evening! please i hope it will be fixed
Old Jan 4, 2023 | 10:58 AM
xploits's Avatar
xploits
No luck.
I reconnected all visible connectors (including the bottom of the A/C button) but it still doesn't work.
Old Jan 4, 2023 | 12:34 PM
Porsche_nuts's Avatar
Porsche_nuts
Are you sure your cable is good?
Did you check it?
Old Jan 4, 2023 | 12:38 PM
xploits's Avatar
xploits
Did you check it?
yes i checked cable.
and find fault code in piwis.
i found something similar
https://www.vwwatercooled.com.au/for...en-120034.html
but i have no power with usb.
for some reason, the usb port or hub could be broken.
Old Jan 5, 2023 | 01:42 AM
NCheok's Avatar
NCheok
Might just be sheer coincidence, perhaps try to order a replacement USB hub.
Old Jan 5, 2023 | 11:19 AM
asellus's Avatar
asellus
Originally Posted by xploits
No luck.
that yellow/red wire I believe is +12v, were you able to probe it to confirm it's getting power?
if you're getting power on that harness, I'd pull the purple one and start checking the pins. two, maybe three, should be supplying +5v. that'd be a good indicator if the hub is alive/dead, or if you have an issue upstream.
Old Jan 5, 2023 | 11:37 AM
xploits's Avatar
xploits
I still don't know which part is the problem
I haven't been able to check the power supply. I'll check it out if possible
Old Jan 15, 2023 | 10:24 AM
xploits's Avatar
xploits
I visited the workshop.
The cause of the symptom is said to be a bad USB hub.
It is said that parts supply will take about a month.
I will share the contents after replacement
Old Jan 17, 2023 | 02:50 AM
NCheok's Avatar
NCheok
So, my diagnosis was right.
Old Mar 17, 2023 | 03:32 PM
xploits's Avatar
xploits
Default fixed now
Parts arrived and replaced.
everything works fine!!!!
Old Mar 17, 2023 | 06:35 PM
NCheok's Avatar
NCheok
Thumbs up
Very glad to hear and happy that I could help.
Happy motoring.
Old Mar 18, 2023 | 12:52 AM
asellus's Avatar
asellus
Thanks for closing the loop on this one! Happy to hear everything's running again. I wonder how unique your experience is with this failure.
Old Mar 18, 2023 | 01:51 AM
xploits's Avatar
xploits
Happy motoring.
thx for supporting!
Old Mar 18, 2023 | 01:57 AM
xploits's Avatar
xploits
thx for supporting!
The usb stopped working the next day after installing rennline mount.
The cause I think
1. passing the charging USB into the lower space of the PCM
2. USB hub damage due to cigarette lighter adapter problem
3. Coincidentally, on the same day, the USB hub broke.
Even in the workshop, the exact cause could not be determined.
and workshop say “It is not a common case”
