Best Headlight Replacement bulbs
i did a whole write up on this, but the chinese LED's i put in my car are amazing! i cant believe how much they light up the road. I replaced the D3S low beams and H7 halogen high beams. I started with just replacing the halogens and was so impressed with them i decided to replace the HID's too. I would never switch back to stock now, and they are going strong for a few months now. No flickering at all, the only thing is that the H7 LED bulbs stay on very faintly when you turn off the car, but its totally harmless. Its just because LED's take such little power to light them, that the tiny amount of power coming from the back of the plug is enough to light them up just a tiny bit. Here is the comparison write-up i did:
https://rennlist.com/forums/991/1341...ned-off-2.html
Schorsch (07-05-2023)
Got to remove the front bumper to get the lights out. Its not as bad as it sounds but its not like the 991.1. Not sure why they would make it so hard other than to boost service hours at dealers.
My 2017 carerra 4S 991.2 passenger side Xenon headlight bulb need to be repalced becuase it does not work ( the high beam and the led works fine) !!
do i need to remove the headlight ( and the whole front bumper ) just to change the passenger side bulb ???
My headlight As shown in the photo below :
In my case, the H7 is a halogen style bulb and the D3S is a much whiter, brighter HID. I'm not sure how much the H7 actually contributes to light output but when flashing lights during the day (headlights off), it's pretty weak. I would ultimately like to color match them and also add brightness and maybe a bit of whiteness to the whole setup. Still researching the best way to do this.....
Please correct me here if anything is wrong...
