Broken vent clip work around
Old Dec 31, 2022 | 02:48 AM
zphiroz's Avatar
zphiroz
Default Broken vent clip work around
While installing a vent-mounted phone charger, I found that my main dash air-vent was loose (completely loose- I could easily pull it all the way out).
After looking closer it appears all the vent clips are essentially broken (the previous owner must have removed it and broken them).
I’m not wanting to replace the entire vent. Anyone found an easy way to stick the vent back in without using clips? Any sort of wedging? Command strips etc? Any other work around?
Old Dec 31, 2022 | 06:34 AM
Porsche_nuts's Avatar
Porsche_nuts
Assuming you can use a piece of cardboard or plastic on the bottom of the vent and wedge it back in.
Old Dec 31, 2022 | 08:45 AM
GTS99ONE's Avatar
GTS99ONE
I have the same issue with my side vent. Prior owner broke a clip so it no longer sits flush in the dash.
Old Jan 4, 2023 | 12:36 AM
ECM's Avatar
ECM
I had the same issue on the outside vents. I was tracking down a rattle and it was the broken clips that were rattling.
What I did first was try to glue them back...no go. I didn't think it would work, but it was easy enough to try.
Here's what worked: I took the vents out and found some small plastic screws in my random *** tool box. The screws were small enough to fit the hole of the metal clip. I think the screws were from a broken remote control I took apart or something like that. I then used a small drill bit to drill a hole where the plastic is melted to the clip. I then screwed the clips into the plastic where the factory melted blob used to be. Some screws were too long and went all the way thru, but it missed the vents so no issue there.
The screws held the clips in well. I have had zero issues since doing this.
I thought I had pictures, but cannot find them at the moment.
Old Jan 4, 2023 | 04:02 PM
CSK 911 C4S's Avatar
CSK 911 C4S
Check e-bay and get some replacement vents.
I don't think even new from the dealer they are that expensive except if you opted for painted or leather vents.
I had all of mine replaced under CPO when the clips ended up on the floor.
