Horn trouble
Horn trouble
Purchased 2013 991 cab 2 years ago right side horn wasn't working Purchased new horns from pelican
installed worked great, next day same side horn stopped working.
Any help would be appreciated
They def shouldn't fail in one day, seems super obvious but did you check if the connector is fully seated, I believe its a weather proof connector which can be sorta tight.
