Ordered from Suncoast, they said it's special order from Germany and possibly back ordered. I figured it would take a month or two, but it showed up in less than 5 days! Installation was incredibly easy, 10 minutes start to finish. I really love the look and manual shifts with the lever are much nicer now
You may find this thread very useful if you decide to update your PDK ****. Keep in mind a new **** with white gear references is coming out later this year if you don't want the yellow references.
fyi you can twist the boot just under the collar and rotate it so it's not all twisted up like that. i was annoyed by how mine looked after install and then twisted it and now it's perfect.
Do the indicators on the **** light up? I miss that to see in which mode the shifter is.With the standard you have to look at the speedo which is unnatural for me .
