My Quest for a Rattle/Buzz/Creak/Squeak-Free 991.2 Interior
#151
Platinum Sponsor
I've been experiencing something that sounded like an object sliding around below the dashboard under the driver's side tweeter area. The sound would only occur when the object would become dislodged when making abrupt changes in direction or while in high-G turns in the canyons. Sounds can be deceiving in terms of where they are coming from so it eventually occurred to me that it might be coming from something trapped in the underbody cover and resonating up into the dash area. I removed the underbody cover and it turns out there was quite a bit of gravel trapped in there. I haven't been able to replicate the sound so I think it has been resolved!
@12v Nick We chatted about this by phone on Friday. I thought it might have had something to do with my install of your tweeter kit but that is not the case!
Glad you found the issue!
I was going crazy trying to think of where a sound like that could be coming from. Makes total sense that it would be the underbelly. We've pulled bumpers on these cars that have multiple handfuls of debris trapped inside — not surprising to see this.
Thanks for sharing!
#152
Thanks for sharing this detailed guide on adding garage door opener buttons! Your <!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->Step by Step instructions and the tools/parts list are really helpful. It's great to see how you've customized your setup. I'm sure this will be valuable for others looking to do the same modification.
#153
Great thread! This needs to be up there with”common failures”.
Guess I’m just lucky cause I have absolutely nothing to add. 2015 Targa 4S approaching 75K miles without a single squeak, rattle, creak or buzz.
#154
I want to let the OP know I made an account just to comment lol. Best Thread ever. A rattle is my worst nightmare, to a point I can hear it in the office. Imagine if every manufacturer had an official rattle fix brochure.
Now, please buy some other car brands
MaddGTS (11-30-2023)
#155
Hey guys I don't have a picture but I found a rattle source that I thought it was my muffler. This will affect mostly pre 2019 cars but only 991.2's. On the passenger side waste gate valve on the turbo there is a steel shield that covers the waste gate connection. It rattles horribly on mine, just touch it with your finger it is very obvious. Driver side is dead silent. On newer 2018 plus cars the shield was converted to an enclosure so no rattle. On very early 2017 there wasn't a shield or enclosure. The sound I experienced as like the baffles in the muffler were loose, buzzing sound.
#156
I eliminated a very annoying tick in my ear by stuffing a towel exactly where you noted. thanks it was driving me crazy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Absolutely epic thread! Thanks so much @devtec!
My “newish to me” 2017 TTS has had a cacophony of interior sounds from the day I bought it. I got rid of a whole lot of these by doing the rear panel and the driver side C pillar per the instructions here. Didn’t do the passenger side at the same time in part because it seemed to rattle less, but mainly because squeezing my obese self into the back and then twisting this way and that had me discovering strained muscles in places where I didn’t know I had muscles.
Anyway, needless to say, fixing the driver side only accentuated the noises from the passenger side.
This weekend I finally tackled the passenger side C pillar. Some noises were reduced but a nasty rubbing and creaking remained. I investigated further and determined that the noises were from the passenger side rear side panel, well below the C pillar trim, which is not something that is mentioned in this thread. Further I found that stuffing a small microfiber towel in the gap between this side panel and the carpeted portion behind the seat bottom all but eliminated the noises (see pics attached). I do not yet know if the reduction in noise is because the cloth towel eliminates the rubbing, or if the thickness of the towel provides a tension to the clips holding the panel on such that noises are reduced.
Any suggestions to make this fix more robust? Obviously I can experiment on what to substitute for the piece of towel to retain the effect but hide it from view, but wondering if the OP or others have been down this path before and can share their wisdom!
#157
This is so helpful, I think it's where my sound is coming from! However after removing the B pillar trim I had a hard time getting to reinstalled. Is there a trick? Like seat the bottom or top edge first? I feel like the clip on the rear lower side against the small rear window isn't seating properly as that edge seems to have too much flex. But maybe it's supposed to be that way.
So on Sunday afternoon I did pull the B pillars out (they come out much easier now!) and added extra felt tape pretty much everywhere it was touching anything. Even put some around the two foam blocks and on the car (metal) side:
In the end, the B pillar is now pretty silent, and goes in "solid". But I still have the slight creak sound under torsion, so I am going to redo the C pillars next.
Will
Will
#158
I am suffering with a rattle at 4k+ rpm in my 991.2 GT3 which is driving me mad. It's a manual transmission, and I believe is coming from the centre console area but is very difficult to pinpoint due to the volume levels of the car at that rev range. It is a loud rattle but very hard to locate. I guess I have to start pulling it apart to make progress, but the usual A/C controls don't seem to be the issue this time.
#159
IRunalot (05-05-2024)
