PDK to MT conversion
You also have to remember that labor in China is probably a lot cheaper. You will need to figure out all the electronics and source that 7MT. But selling your PDK should be easy.
All in all, I am not seriously planning to pursue this. I wanted to know if there were alternative routes in the event of a PDK failure, as T9 design etc have made strides in what was previously an unrealistic PDK repair.
Most likely, I’ll enjoy the car for another year or two, wait for prices to stabilize, then trade for a MT car (hopefully GT at that point).
-install mt 2day
-install clutch pedal and oil line 2day
-wiring 1day
-debugging 2day
1day=8h
AdamSanta85 (05-25-2022)
Where I'm fuzzy and I hope someone can expand on this, I think the manual is largely similar to PDK in its Layout but only one clutch presumably, and a Rube Goldberg device called MECOSA to translate the H pattern shift motions into something the box understands (someone please correct me if I'm off base), so maybe one day some enterprising tech will make it happen but there's gotta be more internal differences because dual clutch vs single - some ratios too, I hear? Interesting topic ! Right now the risks of failure and costs of replacement are probably similar due to the similarity of the internals (remember the reverse light switch we're all under extended warranty for now? affected both).
easy,In my country, Porsche does not offer manual transmission
buy a 7speed box in the secondary market(maybe come from us) and sell the pdk
no awd manual transmission in my country, so i have to remove the haldex.now i am rwd
I spent a total of about $3500
here is my vedio
https://youtu.be/PsG6uelS_zY
here is my vedio
Yes, it is my understanding that the PDK and MT are identical. The difference in the shift linkage/actuators. The shift linkage is some kind of weird magic to manipulate the double shift forks in the PDK. In the 997's the 6 speed was a dedicated tranny and so was the PDK. I guess Porsche decided to save money by using a single transmission. Very creative with the shift linkage and in theory, should make the swap easier.
jfischet (05-30-2022)
Carlton Bale (11-07-2023)
