991.2 Sound Symposer delete
#31
My car is going in next Friday to have all of this removed.
Apparently Toyota make the correct grommets to block off the holes. I’ll try and get some pics and report back.
Having a few other things installed as well. 🤣
4 Point 0 (05-20-2022)
#34
I just tried this and I love the additional noise! It doesn’t sound muffled anymore and took 5 mins. I also discovered the previous owner covered the bare metal with sound deadening material - I guess there were some creak/rattle complaints. Maybe I should remove that too 😉
I captured some high-def interior audio clips with my setup that I’ll share in a bit - much more induction noise and my Turbosmart plumb back valves are much louder.
in my application my sound symposers are still connected inside the engine compartment.
the removal of foam permits/ promotes the following:
-massive increase of induction noise into the car (air flow noises)
-enhanced exhaust note
-gear box linkage noise
-awesome whoosh of air noise when changing gears (not turbo noise)
-enhanced engine noise
-drive train noises (valve,clatter and injectors)
-sounds like a race car
-sound of flowing sand ??? Lol…it’s a funny sound and I like it
it’s still winter around here so it has been really cold …don’t know yet if there is a heat issue.
since the removal of the carpet and foam is fully reversible I suggest to take 10-15 mins to remove everything and enjoy. If you don’t like put everything back.
#35
I tried this and was super optimistic about the results at first when pulling out of the driveway... however after driving around a bit reverted back to stock. Reason being, at least on my T, along with more mechanical noise (that was pleasant) I gained a super high pitched whine that to my ears wasn't desirable.
Was an easy thing to try though, and appreciate the thread regardless.
A question for those who don't have T's, does the rear carpeted panel that pulls off the frame above the sound symposers have slats/vents in it? I noticed that mine does... wasn't aware of that until I popped it off. I know the T is supposed to have less insulation, so curious if that part is different as well.
I only ask because if that part is not common to all trims, it might be an easy upgrade for those who want more mechanical noises in general.
Edit: looks like it is "vented" across all 991.2 trims at least. According to my Google-Fu. Was worth exploring though! Carry on....
#36
Here’s my interior audio clip. Turbosmart plumb back valves and intake/induction noises are much more audible and there is more organic noise that enters the cabin. Now I feel like I just removed the ear muffs off my C4. Don’t think I’ll ever go back.
#37
But once the exhaust is modded, there is plenty of noise and you don’t need the symposer competing.
With all the TiAL tubes and Turbos and catless and Vektor headers, my car sounds great.
I think its perfect values closed. Open is awesome at the track, but a little loud on the street. It turns too many heads on the sidewalk when open and attracts too much unwanted attention. But closed its musical and not in anyones face. Best of both worlds.
AlexZTuned (05-21-2022)
#38
^yeah intake/exhaust is otherwise stock so yeah that’s probably why it wasn’t a huge difference. Based on the video above it’s a different story with some mods!
#39
It’s probably about as loud as you can get in the interior and I have no complaints. But I have a high threshold for sound.
#40
Bump for guys making new Y-Pipe.
The following 2 users liked this post by 4 Point 0:
991ff (05-13-2024),
Dark_horse (05-14-2024)
