991.2 GTS wheel offset
Would these work for my 991.2 GTS?
Can get a really good deal on some wheels that are 20x9 in the front with a ET47 and a 20x12 ET45
I was told front 9's +52 and rear 12's +44 is ideal...
OEM suspension but I do plan on doing the Blistein coil over set up.
Thanks all
Thanks all
In my understanding, our .2 GTS center lock offsets are: 20x9 ET 51, 20x12 ET 63
So ET52 on 9" wheels will be 1 mm more tuck in than our stock and ET44 on 12 are typical .2 GT3 rear offset and it's going to be straight flush on the rear.
However 20x9 +47 (4 mm out from stock) and 20x12 +45 (18 mm out from the stock) seem pretty sweet stance on .2 GTS.
4 Point 0 (02-02-2022)
These wheels will be just fine. My wheels are 20x9 ET 40 and 20x12 ET47. I’m lowered, so they will tuck in a bit more as they go down. For me, it’s a flush and perfect fitment. The fronts of the wheels you are looking at will be 7mm more tucked in than mine, but they will fit just just fine. Rears are only 2mm pushed out than mine, barely of a change. Hope these pics help give you a good reference for your car.
mrneef (02-02-2022)
Guess what????
The new 992 BBS FI-R EVO are 20 x 9.5 ET 46. Near enough.
But rear are 21 x 12 ET 45. Don’t like 21 but may bave to as no one does a decent 20 x 12. Maybe 991.2 GT3?
FI-R EVO
The following 3 users liked this post by 4 Point 0:
I am wanting 20 x 9.5 ET 45 up front and have not bought BBS FI-R because can’t get this.
Guess what????
FI-R EVO
Guess what????
FI-R EVO
I ended up getting the wheels and they are HRE P101. Was such a great deal but needed to confirm the offset worked.
Guess what????
But rear are 21 x 12 ET 45. Don’t like 21 but may bave to as no one does a decent 20 x 12. Maybe 991.2 GT3?FI-R EVO
Guess what????
OP: FWIW, I'm running 20x9 ET45 up front on my C2 without any issues being lowered on Bilsteins as well. I upsized tires to 255/35 as well.
LWG (02-02-2022)
9.5 at et 46 = to 9 at 40, not 34.
I love those EVO Fi-R but I dont think the fitments are optimized, especially if you run that much camber, But maybe you dont care about being hella flush? lol
I was able to snag a set of Satin Black HRE P101 20x9 ET47 and 20x12 ET45 for $4k and only one wheel has a slight curb rash. So will send them to HRE for refinishing and color change for $1k.
Thanks for all the input guys.
isugoo (02-03-2022)
