Replace Frame Rail
We're talking chassis work here? if so, your tie in point is determined by the damage (or rust). You make a cut and that's your welding spot.
Im curious if there is a replacement frame rail that goes from the firewall.
it sounds like you want a front clip, which is generally sourced from a donor car.
