Help Identifying Part
Was doing some cleaning the other week and noticed I was missing the part circled. Can anyone point me to what the part number is for the item circled in red? It helps hold in the engine fans. Thanks.
RPA911 (01-02-2022)
RPA911 (01-02-2022)
RPA911 (01-02-2022)
Last Fall I discovered that a few grommets were missing from my 991.1 engine bay, so I worked with the dealer’s parts guy to get replacements. He could not tell for certain from the diagrams which grommet went where, and thought there were at least 3 different kinds in there. So, I ended up ordering some of each. I figured it out later once the parts arrived:
991 624 353 00 grommets -- replacement part number 9P1-959-841 -- hold the 2 front posts of each fan to the sheet metal. They are larger than the other 2 types and have a felt washer.
958 110 673 00 grommets -- hold the single rear post of each fan. These are also used on the 4 corners of the fans to hold down the plastic engine cover.
997 110 239 00 grommets -- Two of these grommets hold the engine’s plastic upper intake Y pipe (air guide) to the sheet metal. Also 3 of these hold the small plastic triangular right engine cover to the sheet metal.
The following 2 users liked this post by Southbranch:
poorshoeless (01-02-2022),
RPA911 (01-02-2022)
