Powerkit for Porsche 911 Carrera S
Old 11-21-2021, 12:53 PM
Ginzo
Ginzo's Avatar
Default Powerkit for Porsche 911 Carrera S
Can the OEM Powerkit for the 991.1 be bought from Porsche? If so would it be best done by the dealership? Anyone with cost estimates? I did a search and didn’t find anything.
Old 11-21-2021, 12:58 PM
asellus
asellus's Avatar
Received 2,105 Likes on 1,311 Posts
I was under the impression that the powerkit had been discontinued, but places like Suncoast list it for sale for a cool $11k.
Ginzo (11-21-2021)
Old 11-21-2021, 09:06 PM
Msgm1
Msgm1's Avatar
I think it require a lot of work to install, when I asked it was c$5k for labor alone if my memory serves me correct
Ginzo (11-22-2021)
Old 11-21-2021, 10:16 PM
asellus
asellus's Avatar
I could believe this. It's a bunch of intake related stuff at the very least.
Old 11-22-2021, 01:06 AM
Southbranch
Southbranch's Avatar
From the Porsche Bulletin:
A parts kit is available for increasing the performance of the standard engine.
Increased performance is achieved by implementing the following measures on the engine:
• New cylinder heads with flow-optimized intake ports, valves and valve springs.
• New intake camshafts.
• New resonance intake manifold with switching flaps (material: aluminum sand cast).
• Modified maps for the DME control unit.
The following additional modifications are also required and the following preconditions must be met on
the vehicle side:
• New engine cover with carbon inserts, painted Titanium Grey.
• Sports exhaust system incl. tailpipes (if not already fitted).
• Radiator –middle– (I-no. 153).
Retrofitting:
If the engine to be converted has a mileage of over 25,000 miles (40,000 km), the crankshaft main
bearings and connecting-rod bearings must also be replaced.
If there is obvious wear on the connecting-rod bushings (scores), the connecting rods must also be
replaced.
The following 4 users liked this post by Southbranch:
CaliCarrera (11-23-2021), fluguy (11-23-2021), Ginzo (11-22-2021), pride355 (12-18-2021)
Old 11-22-2021, 07:00 AM
Robert Kaufman
Robert Kaufman's Avatar
Default Power kit for 911S
Best way to go is with the GTS. 991.1 has 430HP
The following 2 users liked this post by Robert Kaufman:
CaliCarrera (11-23-2021), RobC4sX51 (11-23-2021)
Old 11-22-2021, 08:22 AM
Guards_Red_991
Guards_Red_991's Avatar
OP: I think the best way to get some gains is installing long tube headers with a good exhaust, replace the plenum (IPD maybe?) and a custom tune. This should set you back under $10k, keep the internals intact.
Ginzo (11-22-2021)
Old 11-22-2021, 11:35 AM
AdamSanta85
AdamSanta85's Avatar
Received 1,242 Likes on 728 Posts
I would give BGB in Florida or DeMan in NY a call. They know how to build our engines for all motor power, mostly learned form 981 GT4 with same motor.
Otherwise RR Racing can get you more power with a supercharger.
Last place I would go in dealership. Unfortunately 99% of them don’t know anything but how to do overpriced oil changes.
The following 4 users liked this post by AdamSanta85:
desmotesta (11-22-2021), Ginzo (11-22-2021), PCA1983 (11-22-2021), PorscheC2S (11-22-2021)
Old 11-22-2021, 03:54 PM
Joec500
Joec500's Avatar
Received 1,020 Likes on 606 Posts
Also these guys for stroker 9A1's
https://flat6innovations.com/9a1-9a2-engines/
BBi I believe does a stroker kit for the 9A1 motor too, and they are super legit as well.
Old 11-22-2021, 04:03 PM
Ginzo
Ginzo's Avatar
So if you do the math 11k from Suncoast and 5k for labor for a gain of 30 hp that comes out to $533 per hp. As suggested it would be better to get a GTS. My car plus 16k probably would not get you a GTS but in the long run it would be a better investment when all things are considered.
The following 2 users liked this post by Ginzo:
fluguy (11-23-2021), Robert Kaufman (11-23-2021)
Old 11-22-2021, 04:06 PM
AdamSanta85
I have same car as you. I’ve done intake, headers, exhaust and tune… I have four options I consider…
1. DeMan 4.5L, $29k installed, 500whp on pump gas
2. RR Supercharger, $13k?, 450whp on pump
3. Dundon intake runners, $3800, supposedly good for another 25-30whp, let’s say 400whp
4. Sell car for Carrera T, $30k
Ginzo (11-22-2021)
Old 11-22-2021, 04:56 PM
PorscheC2S
PorscheC2S's Avatar
Supercharge it and get reliable 500+ HP at the wheels. RR does it! I think the whole cost is like $15,000 too!
Old 11-22-2021, 05:22 PM
desmotesta
desmotesta's Avatar
Received 2,015 Likes on 957 Posts
[QUOTE=AdamSanta85;17801353]I have same car as you. I’ve done intake, headers, exhaust and tune… I have four options I consider…
Best option IMO
Old 11-22-2021, 07:56 PM
justbob
justbob's Avatar
991.2 with a tune.
Old 11-22-2021, 09:04 PM
desmotesta
desmotesta's Avatar
Originally Posted by justbob
991.2 with a tune.
what if he already has a Dyson?
The following 4 users liked this post by desmotesta:
fnckr (11-22-2021), poorshoeless (11-22-2021), RobC4sX51 (11-23-2021), Z00mie (11-25-2021)
Quick Reply: Powerkit for Porsche 911 Carrera S
