What is the RL recommended tire pressure for my ‘19 Carrera 4 GTS?
I set tire pressure to TPMS targets for partial load, comfort, as recommended by my service advisor.
Those PSI values are different than what is in the manual.
29 front 31 rear, or 31 front 33 rear on comfort settings
thesaintusa (11-04-2021)
I run mine on comfort pressure, if you do that make sure you select comfort setting on the dashboard MFD, otherwise you will get an error TPMS light. With cooler weather, you might have to add a few pounds of pressure to your tires.
Whatever your car calls for when you set it to "partial load" or "comfort" -- these are the lower pressures that most RL people recommend.
Your TPMS won't yell at you until you're something like 4 or 5 psi below the 'comfort' fill levels, and it won't yell at you for overfilling either, so there's your range.
