Does 991 Need to Lifted at 4 Jack points for Oil Change?
Old 11-09-2021, 09:21 AM
  #46
Rich_Jenkins
Rich_Jenkins's Avatar
Originally Posted by Tier1Terrier
@Rich_Jenkins 2 Questions... So which OBD tool would you buy then? MX808? ICS POR V2.0? or 3.0? I know this has been discussed in other threads but I'd like to know where you'd land on this.
Also, What's the red/black screwdriver handled tool you got there? Is that for drain plug removal?
And while we're at it... What was in the white plastic bag and what about your torque wrench?
Ref OBD tools, I dunno. I am ok with my Autel unit for annual oil change resets, so that's kinda all I need at the moment. I guess I would pick the iCarsoft based on positive reviews here? But I would defer to the folks with more up to date experience/info.
The red/black screwdriver is the "Audi/VW" oil pan plug removal tool. I was a bit OCD about my first OCI and someone or other recommended it. Turns out a Philips, or a 2 Euro coin, will work fine to quarter turn the plug, but OF COURSE I had to have the tool:
Amazon Amazon
The white plastic bag was what the new oil drain plug came in.
My torque wrench is off camera.
Old 11-09-2021, 06:44 PM
  #47
CBR997
CBR997's Avatar
I have read nothing but good things about the Schwaben jacks. Thanks
Last edited by CBR997; 11-09-2021 at 06:45 PM. Reason: did not go to the post I wanted
Old 11-09-2021, 08:26 PM
  #48
Valvefloat991
Valvefloat991's Avatar
Here's a photo of my oil draining with my 991.2 flat on the floor of my garage. The large, shallow drain pan easily fits under the car and accommodates the engine's copious drain oil. The only trick is reaching between the bottom of the oil pan and the top of the drain pan to undo the the plastic oil drain plug. Using the plastic tool designed for that purpose makes it easier as the tool is pretty short.
The following 2 users liked this post by Valvefloat991:
marinb (11-14-2021), NI3 (11-13-2021)
Old 11-13-2021, 07:13 PM
  #49
CBR997
CBR997's Avatar
Picked up my new jack this week. Also picked up some ESCO jack stands. Jack works great. Haven't done my oil change yet, but am getting ready. Thanks for the help getting me on my way.
Old 11-13-2021, 08:11 PM
  #50
NI3
NI3's Avatar
Love it, why complicate it.
Elmiko (11-14-2021)
Old 11-14-2021, 02:11 AM
  #51
Joec500
Joec500's Avatar
Received 1,021 Likes on 607 Posts
won't work with lowered cars LOL
Old 11-14-2021, 06:22 AM
  #52
NI3
NI3's Avatar
Of course, won't work on numerous modified cars. Just as some floor jacks will not work in all scenarios. I was simply commenting about a specific situation. LOL
Old 11-14-2021, 12:39 PM
  #53
HkPlinker
HkPlinker's Avatar
Originally Posted by Ark20
Same car/year as yours. Waiting for my oil kit to come on Monday from fcpeuro. $85 approx for 5w40 liqui Moly with filter etc. i use icarsoft por II for reset. Bought the tool off a fellow forum member. Recommended for maintenance resets.
DYI oil change done and was satisfying. I found the 36mm deep well socket and 8mm mid length hex socket at Napa (in stock) for $ 20.00 for the two and the Pittsburgh ramps were 20% off at Harbor Freight.. The only advice is pour the new oil in slowly, very slowly. I was not able to use a lockable oil fill funnel. Went with a wide mouth and poured in from 5 quart jugs.
I first got the car to operating temp before the drain and let it sit for over an hour. Replaced and primed the new filter, got the car back on level ground and poured in just over seven quarts. Did the IcarSoft reset and the oil was at the bottom "Minimum" oil indicator mark.
I filled 1/2 quart and had to do a total of three 1/2 quart fills to reach the "one marker" below the top level line. Drove the car for a few miles and re-checked the oil level. Still right on the one mark below "Top Fill".
Oh, I did noticed when removing the engine cover the foam seals that seal to the air box are deteriorated and some has fallen off. Checked the engine filters and did not see any loose pieces of foam.
I have some 3M single side "sticky" foam that might work, but is a little more "firm" than the factory porous foam seal. Thoughts?
NI3 (11-14-2021)
Old 11-14-2021, 06:25 PM
  #54
barncobob
barncobob's Avatar
forgot about my oil change,,due here in 400 miles..will do this week as weather is gorgeous..
Old 11-14-2021, 08:50 PM
  #55
poorshoeless
poorshoeless's Avatar
Used my QuickJack.. before that, I just back the car out to the edge of the garage and do it, it's tight but doable.
991.1 C2S on QuickJack for oil change
Old 11-15-2021, 11:21 AM
  #56
Martin S.
Martin S.'s Avatar
"Dang if they all didn't disappear though. )". Now this is a good idea! I am into Porsche Service this week, and they'll have a box of donuts to chew on!!! Sad to say, I don't get any!
Rich_Jenkins (11-16-2021)
Quick Reply: Does 991 Need to Lifted at 4 Jack points for Oil Change?
