Help removing dash knee pads
Before I start pulling or prying, any help regarding removing knee pads would be appreciated. Switching leatherette to leather in the interior.
Have all the parts. Time to get to work.
From what I recall, remove the trim for the key/headlamp switch, remove the trim on the other side, remove the instrument surround, then the pull cluster (yes seems odd, but I remember having to pull mine out-not disconnect). I believe there are a couple torx screw that are accessed when it’s out of the way. Remove the drivers side center console trim, then the remaining screws holding the bolster on. After that I believe there are one or two clips holding the bolster on and the electrical connection for the light and parking brake release.
cicsprog (10-31-2021)
Have you checked the FSM? A lot of PDF instructions posted are just excerpts from there.
