Paddle Extensions
We already have you covered! as far as I know, our 991.2 grill screen kits are compatible with the active air intakes. just select your model and other options and you should be good to go!
https://www.rennline.com/Rennline-Ra...ctinfo/E1000//
I ordered the Rennline extensions after checking with them if it’s compatible with the Sports + dial on the steering wheel. They offered to pay for shipping back if it doesn’t work out as they weren’t 100% sure. I didn’t attach it, but holding it there, the bottom does slightly touch. It doesn’t seem to impact the shifting action, but not sure if I should keep them. Is there a concern if it’s touching, other than potential wear on either part?
If you could send a picture to Tech@rennline.com, we will certainly get those back for you and issue a refund. this sounds like a less than ideal installation. We would not want anyone to be unhappy with the extensions for this reason.
