Is My Seat Motor “Going Bad?”
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I had posted: “Storing Personal Settings - not working anymore” 11-2020
Porsche said: Somehow, seat memory lost calibration”
Fix was for me to Reset by moving the seat all the way in every single direction. It was time consuming & then I had to find my position for all those 14 way adjustments.
Then 6-2021 I posted: “Trigger Loss of Seat Memory?”
I again had to do the long reset procedure.
Today, the seat “went crazy!”
I was driving and suddenly my seat moved FW, by itself, a few inches! Did not do this smoothly. Rather in a few ‘spurts.’ As I wondered WTF just happened, the seat started moving BACKWARD & kept going till my feet could barely reach the pedals.
I found a place to pull off the road.
I tried pressing seat memory #1 button & it did move back to correct position but, immediately moved way back again!
I played around with it, shutting off ignition, opening door & restarting engine, etc.
I finally got it Into a position (not my memorized position) where I could drive it & I drove home.
I have a voice mail in to my Porsche SA.
I do not want to merely do the reset procedure & spend lots of time finding & storing my ideal seat, mirror & steering wheel preferred settings again, bc I think something like this will happen again.
Some mechanical part needs replacement.
Seat motor?
Some module?
Any suggestions appreciated.
(2019 C2S, still under factory warranty.)
Seat motor?
Some module?
Seat motor?
Some module?
Seat motor?
Some module?
TwinTurbo420 (10-15-2021)
Sounds like the switch pack is hoopajooped. Could be munched up wires/connections under the seat, too. Adjust the seat to the highest, most forward position it can go to, and get under the back of it and look for any damage.
Given it's a 2019 and under factory warranty though, just take it in to the dealer and let them deal with it. Let us know what they find.
Finally had my Appt. wi Porsche Service. Last Monday. My concern had been that it would not exhibit the intermittent problem during the test drive & the tech would merely do a reset, which I know would not fix it.
Over the past weeks since this began, It did the movement on almost every drive.Often 2-3 times. I learned to quickly press door button #1 to stop the seat from moving & press & hold to achieve my saved driving position.
Luckily last weekend, b4 my appt., I accidentally discovered how to trigger the malfunction. Open driver door, car is off & key in my pocket (I have entry & drive) W/o sitting in car, press down fairly hard with my fist on the driver L bolster or the seat bottom. This triggered the seat to move! Sometimes only a few inches & other times It would move fully FW & then fully backwards!
I demonstrated this to the shop foreman who seemed amazed by it! He took a video of it on his phone.
They fixed it by the next day.
Replaced the switch seat. (The entire silver control on the left side of seat)
1 P/N: 7PP-959-747-AA-DMN switch, seat
4 P/N: 947-007-483-00 Outer Hexagon RO
(IDK what the Outer Hexagon RO is.)
I had asked them to top off coolant while car was there.
Today I checked & they did as I asked but, new problem:
The rear Engine Lid no longer stays up!
I made an appt. for November to replace the struts.
I was told that is a common failure when weather gets cold. Same with Front Frunk Lid struts.
I will make sure my Frunk struts are working perfectly a few months b4 warranty expires.
