Very weird acting transmission. 13’ 911 S
@MikeNJ What exhaust system do you have mate? It sounds glorious.
Thanks. I’m not really sure because the previous owner did something to it. But here’s a copy and paste of what a Porsche mechanic had to say about it during an inspection.
it also has some kind of upgraded exhaust tips
“My technician found a slight suring upon acceleration. He inspected on lift and found the side mufflers were removed, sport exhaust ports welded shut and the outlet center muffler welded closed with the exhaust pipes welded directly to the pipe leading to the center muffler. This may cause back pressure in the exhaust.”
Guards_Red_991 (09-10-2021)
hey I just checked and the reverse lights are working.
engine off, key turned half way, clutch in, put in reverse.
what does this mean?
