Educational video: Will the brakes from a different car/trim level fit my car?
Basic Sponsor
We get this question or see it posted here on the automotive forums just about every day. It often stems from a desire to add disc thermal mass, or just an aesthetic upgrade, without investing in a complete brake kit (which is fine if done properly!). Unfortunately, the process of swapping the discs from one car to another isn't quite as simple as it seems, even when the new discs appear to be the 'same size' as the ones already on your car.
In our latest video we examine the critical disc dimensions that determine if the swap will work on your car vs. leaving you with some very expensive paper weights!
0:00 - Introduction
0:55 - Disc Diameter
1:17 - Disc Thickness
3:12 - Radial Depth
5:20 - Offset
6:42 - Mounting Pattern
8:25 - PCD
Be sure to check out the Essex Learning Center for more videos and articles on brake tech.
Thanks, and hopefully some of you find this information useful.
0:00 - Introduction
3:12 - Radial Depth
5:20 - Offset
8:25 - PCD
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
![](https://rennlist.com/forums/signaturepics/sigpic110137_8.gif)
Jeff Ritter
704-824-6030
spyderbret (08-24-2021)
