2018 4s brake squeal.
Old 06-10-2021, 11:55 PM
Jack F
Jack F's Avatar
I get some brake squeal when backing up and braking. Need to do so to get the car into driveway/garage.
Old 06-11-2021, 12:03 AM
ipse dixit
ipse dixit's Avatar
Received 12,021 Likes on 5,238 Posts
Your'e not driving it properly.
Or more precisely, you're not braking properly.
Stomp on those suckers every once in a while.
Old 06-11-2021, 08:05 AM
mjposner
mjposner's Avatar
Mine squeal too. Normal per Porsche (wenn es quietscht, wenn es funktioniert) is what they would say, I am sure. Some of us have moderate speed traffic commuter drives so not much chance to wind up and slam on brakes.....
Old 06-11-2021, 11:52 AM
Dgags
Dgags's Avatar
The 2 remedies most suggested are new brakes or a hard stomp. Going for a quick drive at 5am on a Sat or Sun seems like an easier fix than doing a complete brake job.
Old 06-11-2021, 03:22 PM
Picketthouse
Picketthouse's Avatar
Originally Posted by johnstoy
The video and Mike have it: the squeal will go away with some harder use. If the car is mostly cruising in traffic with light brake use the noise will get worse and worse. The brakes need some heat and wear to smooth things out. You don't have to break any local laws... but some spirited driving and hard braking will help.
I will give this a try as my car is a daily in town commuter.
Quick Reply: 2018 4s brake squeal.
