Possible 991.1 GTS Purchase
I'd recommend a few mods to maximize your enjoyment.
My personal must-haves:
1) Get a DSC v3 suspension controller and have it installed. Night and day improvement in handling both during aggressive driving and comfort during normal driving.
2) Consider doing the JoyeAuto CarPlay retrofit. It works really well and then you don't have to deal with the ancient-feeling PCM v3.
3) Exhaust upgrade. I have the akrapovic which is expensive but sounds absolutely insane wide open and is very well-behaved with the valves closed. The sharkwerks is a cheaper option which still sounds great (but I'll be honest not *quite* as good). You're getting an NA car... trust me, this is worth its weight in gold in helping your car sing. Don't bother with headers tbh. Almost no power to be had and you'll rule out CA buyers if you ever sell it.
4) Retrofit the 991.2 steering wheel. The 991.1 steering wheel (especially the non sport-design one) is clunky and unrefined by comparison. You can instead opt for the 991.2 multifunction steering wheel by using a "GPS adapter" (https://gpsadapter.us). Just email the guy with what you have and what you want and he can recommend the needed adapter. This also lets you eg; use the multifunction switch on the steering wheel to set the mode (eg; Sport+).
Nice-to-haves:
1) I've realized you can get *HUGE* steering and handling improvements just from suspension upgrades alone. The SPASM is solid if you have it (and paired with DSCv3). But if you have regular PASM consider upgrading to tractive DDA coilovers or Bilstein B16s (a more economical option) along with the GT3 sway bars. You can then run a little bit of negative camber and you'll get a much more responsive feel. Even better, TPC racing sells a front axle width increase kit that increases the front track width a tiny bit the "proper way" (i.e not using shims). Drastically improves the handling for the better.
2) The OEM aluminum gas cap. Stupid, I know but trust me you'll smile every time you fill it up.
Enjoy. It's a beast of a car and prices seem to be continuously climbing (and the cars are indeed selling at these prices). It's pretty much the ultimate naturally aspirated Carrera.
Nice-to-haves:
The above information is mostly true.......
1&2 - yes for sure
3 - kind of? Sharkwerks doesn't make an exhaust for the GTS since the GTS has PSE, so if you use their bypass pipes you lose the PSE option of switching. There are lots of options here though with fabspeed, soul, IPE (what I have), akra, etc.
Not sure what he's talking about with the headers, I just put Klines on mine and now at launch it's crazy how much wheel spin I get in comparison and how well the torque is distributed thru the powerband, it's noticeable for sure AND the sound is just perfect! Now when I don't have the PSE switch on, I get more growl in the exhaust sound. So instead of having ZERO sound or INSANE sound, I get a nice growl with no drone or hit the button and I get classic F1 style scream (IPE thing).
4 - Absolute MUST get if you have PDK, especially if you have PDK with multi function and the stupid "buttons" for PDK shifts.
The car did have the big 4 year service done by the dealer and is being CPO so I'll get 2 years unlimited miles from the time I purchase.
It’s a sports car, IMO it should start up in the sports mode.
You can also decide if you want the exhaust mode on or off at startup independent of the sports mode.
Enjoy the car, your going to love it.
