A few stereo & multi-function display questions (991.1)
I tried searching but didn't find answers. A few quirks that I haven't figured out:
Thanks in advance for any tips!
- I see pictures of people's MFDs that digitally display oil temp, etc. I can't seem to find how to enable that?
- Similarly, I understand the MFD can display radio information, can't seem to enable that either.
- Volume level? I don't see that anywhere on the radio display or the MFD when I turn the volume dials up or down.
- Radio presets, is this limited to 6? Can't seem to see more than 1-6 on the screen.
- GPS. I disabled auto-zoom because it would take me to a national map and then manually zoomed to a resolution I prefer. However, it seems to revert to auto-zoom; any way to disable this / is it related to the "key"?
- Aux-in/Bluetooth, any way to make it discover my phone each time? My phone does automatically connect for other functions, but I don't see Aux-inBluetooth as an option when I select Media unless I go through the menus to enable it each time and connect to my phone.
Scroll down the messages on this link: https://www.6speedonline.com/forums/...h-display.html
It will explain how to change the dash display to read voltage, coolant temp., oil temp., oil pressure, etc.
The two things still pending:
- How do you display volume level?
- How do you lock the map resolution so it doesn't change? I tried it again and set the 3/key, so maybe this time it'll stick.
Thanks, I actually did customize that setting initially but didn't recall seeing the choices for oil temp, etc. Just got back in from trying it a 2nd time and found those settings when I scrolled UP. I also was able to add the radio function on the display as well.
I think you can adjust the alerts and alarm warning volume to high, medium, low.
You can also adjust the telephone ring volume and I think GPS volume to a high of 8 or 10.
The volume can be displayed in the 991.2 on the PCM as a horizontal red ribbon bar.
991.1 owners have indicated that this is not available on their cars.
