PCM supported file formats
Hi!
I know there are a bunch of threads on the PCM which I have read.
I'd like to get this in one place. When playing music through the PCM via USB or SD Card, what formats are supported?
AIFF?FLAC?WAV?MP3?
Will the PCM play any lossless codecs?
Thank you!
AIFF?FLAC?WAV?MP3?
Thank you!
Plek (01-13-2023)
Last edited by docskeet; 05-17-2021 at 07:56 PM. Reason: Posted on the wrong thread
Sample AIFF Files Download - Get Examples Instantly (filesamples.com)
On my 2018 991.2, I can confirm that the file will NOT be recognised by the PCM.
However, you could use a batch converter e.g. dbpoweramp to convert from lossless AIFF to lossless ALAC
Hello.
I just wanted to bring this thread to a close.
@jchasty thank you. I can confirm that the PCM will in fact recognize and play ALAC.
I have used DBpoweramp to convert my AIFF files to ALAC and the PCM displays them with graphics and processes the audio just fine.
Now if Porsche would just expand the ridiculously low 128GB SDcard limit I could get my entire library in there : )
jchasty (07-18-2021)
just out of curiosity: Was anybody able to play a VIDEO format through the pcm. Inserted a movie DVD and it played the audio. (at least)
Anybody played some video? What format?
Hello.
Ooooo, I'm pretty certain I'm using a 512Gb SD card.....
Thanks for the info regarding XM Sirius board. I’ve upgraded the boards in my stereo gear before and debating if I should try and do this install myself or get a pro (I’m in NYC and image it would be rather expensive). Seems like the back up camera would help to have a pro install.
