Possible to re-noise insulate 991.2 Carrera GTS?
Hi
My stage 2 GTS is quite loud from the inside. The GTS has noise insulation parts stripped as opposed to a normal Carrera. Is it possible to reinsulate the noise insulation part into the car? Has anyone ever done this?
Cheers
Cheers
Yes... a few people have done it (myself including) on a 991 GT3. This is only one of the threads: GT3 DIY sound insulation - Rennlist - Porsche Discussion Forums
It's fairly easy... just time consuming. Took me about 4-5hrs, but I did the doors as well.
JC Lacayo (04-23-2021)
I got some Noico to do just this. But haven't gotten around to it and I've grown accustomed to the 'loudness'
Just do a google search, there are so many videos and posts out there.
Door panels are easy too, 4 plastic panels that pop out and then 4 screws... then the door panel just lifts up.
ExternalGPU (04-23-2021)
Honestly, they all just pop out. I just used my trim removal tool to get under... The only thing that has a screw is the rear middle panel (on my GT3) since we don't have rear seats.
Correct me if I am wrong. Does the insulation tape only go to the rear seat/storage area and the doors? Did you remove the seat prior to installing the tapes?
How about the footwell? Under the seats? How thick did you do?
I bought the ones from Amazon... they are referenced in one of the posts. I did a 2 part, like a few members in that thread i posted. I had to unbolt my seat and move it forward in order to get in the back. My GT3 has a roll cage so it's harder. I did, pretty much, everything from the back, where your seats would go, to the rear trunk area. Didn't do anything under the seats or in the drivers area as the engine/exhaust noise is in the back area. The doors helped with some of the wind noise and it made the stereo sound much better, in all honesty.
Motor noise
If its motor noise plug the sound hole.
rubycaymanr (04-26-2021)
