Don’t scrap the Bose before you adjust the settings!
The following 4 users liked this post by mekkiz:
#47
I've got the Burmester. In ways its better than the Bose but the Burmester sucks. Bad. The system in my bucket daily truck is leaps and bounds better than the Burmester. The truck has budget pioneer speakers and a good quality 10" sub from amazon.
In the Burmester, -6 bass is still enough to blow the speakers and rattle the entire car. Sometimes I can get away with -3.. Anything above is suicide from the interior trim. I can listen and play anything form 90's gangster rap to classical to metal/jazz/rock/pop/electronic. The Burm still can't produce certain sounds/instruments that headphones or my budget amazon system in my truck can. Bose is worse.
Nothing should be offered in the 911, just give me empty speaker slots and I'll put my own stuff in there next time... Sounds absurd, but the Bose and the Burm BLOW.
PAPorscheGuy (03-29-2021)
#48
#49
I’m curious about the comments regarding a visual volume display.
On my ‘19 911, at the top of the tuner screen, a red ribbon is displayed that lengthens/shortens as you increase/decrease volume.
So some of you don’t have that?
#50
my 2017 911 doesnt have the red ribbon. my moms 2020 911 does. so clearly different firmware.
#51
Touche’ - the consensus seems to be there are problems at all frequency ranges, but the biggest issues are apparently are at high frequency as several here have replaced tweeters. CarPlay (.2) and unchecking Linear definitely helps. Thank goodness I have PSE
#52
Received 5,402 Likes
Remember when we all had those equalizers with the bouncing light-bar graphs? That's what the Bose system needs.
#53
Also cracking up a bit at the idea that cars aren't a fantastic listening environment, so it's best to save listening to music for when one is at home. By this logic, I would have sent pretty much every musician and every audience home—but, working with what we had, and most rooms were/are terrible, we created experiences that moved people. You tailor the sound to the space you've got—but to do that, you need a certain amount of equipment with the ability to tailor it. Same goes for cars. Did a drive in an old 914 with a Mezger six on Saturday, and it was heavenly. There's no radio right now, and I didn't miss it a bit. But I've also had some memorable audio experiences in cars over the years, too…
If someone came up with a plug-in/interuptus device or reflash to add an EQ to PCM, I'd be all over it. If it could be set up to counter tire noise, even better.
#54
^ Yes x10,000. I'd rather have an EQ before better tweeters. First step should be improving/tailoring the signal to what's there. Treble and bass only is LOL bad. What were they thinking, and with a big fancy screen where an EQ would have been a cinch?
#55
Could you both check your versions? It's under Car > Set > Version Information (or Software Information or something very similar). My software version is MHI2_US_POG11_K3300 0809, with hardware version 051.
@BSO I'm most interested in seeing yours.
The other thing that comes to mind is I almost exclusively use android auto on my PCM4. Next time I drive I'll try adjusting volume while on the radio or bluetooth source instead, see if that changes things.
#56
2017 and 2019 should both be PCM4 on the same firmware that I have on my 2017. I wouldn't be surprised if the 992 has different hardware on top of software.
Good idea. I will check the software version. Maybe its a firmware update, possibly hardware.
Will also post photo(s) to show you. Interesting it shows up (very briefly) using the radio tuner, bluetooth, and CarPlay, but only when i use the volume **** on the console, not the volume dial on the MFSW!
#57
Using an Ipod is not a bad option esp since you can get CD quality if you choose that option when you download to Itunes. If you have an old Iphone or Ipod Touch laying around try it. The Ipod has a few EQ settings which can be helpful....I use "Acoustic". But as mentioned previously the best results come with using an app called EQU which is a parametric EQ and you can make a LOT of adjustments. I think it's a free app or cheap anyway. Downside is when you use EQU you can't skip tracks or pick music from PCM. It manages the music.
The right product is either a way to hack PCM into having an EQ screen (if APR can do it for the engine…) or an inline EQ that can affect the signal between PCM and the amp. I'd buy either in a heartbeat—particularly if the user interface was good.
#59
^ Yep. I've thought about loading up an old iPod and just keeping it in the glovebox, but not sure I want to support it and it doesn't provide Pandora or, for that matter, FM—while EQU is interesting but forces that interface…which is what I hate about our Sonos system in the kitchen.
#60
FW 4.76 on 991.1 - most current? - and no red ribbon no nothing. Unfortunately.
Sidenote: Listened to some bad *** tunes on my Bose: Killing in the name of…Rage…full blast…pretty descent output and recognition to my ears.
Maybe my ears are old and destroyed from all the concerts in my youth!?
