Motul 8100 X-cess 5W-40
I'm considering trying Motul 8100 X-cess 5W-40. If you have used this oil in your 991.1, can provide your opinion please.
Cool, another oil thread. I need some entertainment..
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Fair enough, these threads usually cause some... friction. But seriously, as long as people stay aware from "Bro, the oil you HAVE to use is..." then we should be OK.
On that note, check out the Ester based Motul Sport. Particularly at higher heat (and for those with the .2 we generate a lot of heat) the viscosity results compare favorably with X-cess. The sport is a bit harder to find.
BTW, I've run this in my 996tt for many years with good results. 991 is new to me and I'm running a Porsche Service fill right now. And as said above, there are many good oils. My local Indy fills customer cars with X-cess.
I have not used it, but I intend to. LN Engineering recommends it and I trust them.
found here.
For some time I believe that the Gen2 product did not carry A40 approval. It seems that the Gen2 formula was created to meet BMW LL-04 and has since been approved by Porsche as still meeting their A40.
For Porsche approved lubricant we use and recommend Motul 8100 X-Cess 5w40.
All you touting Motul 5-40 do have UOAs and have you compared the wear metals to other oils/UOAs? I have been using it for the last 4 changes and I am just (disappointingly) realizing my wear metals are typically consistently higher when compared to other oils/UOAs. I will be adding Ceratec and see if this helps and which will be evidenced by my next oil change's UOA. This is however on a 997, YMMV.
BTW I thought LN recommends DT-40 (which I will be switching to on my next oil change based on UOA results I have seen and compared)
Carry on ...
Carry on ...
Carry on ...
Carry on ...
I put it in for the first time, no issues an has not burned any. I'm sure its as good as mobile1 or others. I was worried that mobile 1 may be following other manufacturers model now that they have the largest market share and may be cutting cost/quality. I have no proof but this is a repeatable recognizable pattern in corporate america. If you can't get 15% growth a quarter something has to give or someone is gonna get a 5 foot shorter yacht.
I find the best prices for Motul stuff is www.RMEuropean.com. I don't trust Amazon not to sell me fake Motul.
I am tempted to try the 300V next time. Warranty is up in May anyways....
https://www.rmeuropean.com/Products/...e-e283f201464a
I've been running Motul 8100 X-cess 5W40 in my Mezger Turbo and now the 991 Turbo for a while, good stuff and IMHO a better choice for a street car.
