Motul 8100 X-cess 5W-40
Old May 9, 2021 | 01:03 PM
Ceepe's Avatar
Ceepe
Great oil. I run it in everything, including GT3's, turbo Carrera's, VAG 2.0's, etc. Currently just changed my Carrera T with Motul x Max 0-40 because I wasn't seeing much 5-40 available when I ordered, possibly because of the switch to the gen 2, which I haven't tried yet. Big fan of Motul.
Old May 10, 2021 | 10:26 AM
tarheel15's Avatar
tarheel15
Default My experience
I have two observations in my 991.1 GTS using Motul X-Cess 5W-40 compared to factory Mobil 1. First, upon cold start-up using Mobil 1 there was quite a bit of engine clatter until it reached operating temperature. Porsche service claimed this was normal. The Motul eliminated the clatter. Second, after a big, hard run using Mobil 1, I would check oil level in my garage and noticed more often than not it required a top up. Under the same conditions, the Motul has never required top up. Just my two cents from So. Cal. running the Angeles Crest.
Old May 10, 2021 | 10:41 AM
AdamSanta85's Avatar
AdamSanta85
The Blackstone Oil Analysis for this oil is disappointing. I am moving on to M1 5W-50.
Old May 10, 2021 | 10:48 AM
Sporty's Avatar
Sporty
Yeah, like I said in my posts 3 months ago. It contains no Molyb. as far as I know, not sure why. Without reviewing my UOA's I would have said its is fine as well, engine runs fairly quiet and does not burn this oil that readily, but the wear metals are disappointing at least for me. YMMV.
Old May 10, 2021 | 10:56 AM
desmotesta's Avatar
desmotesta
My observations with the same oil and same car are slightly different. The cold start "chain?" clatter is still there for me, but not present all the time. On the subject of oil usage, I agree, I now have a little over 4300 miles on the car and oil gauge has not moved a single bar which is not how it was on Mobil 1
I will pull a blackstone report once i do an oil change and make my decision based on wear items.
Old May 10, 2021 | 10:57 AM
AdamSanta85
It also shears down which is my biggest gripe. I have two disappointing UOA's on my car with Motul 5W40.
Old May 10, 2021 | 06:06 PM
pfbz's Avatar
pfbz
Can you be specific on which Motul 5W40 you were using and had analyzed, as several have been mentioned here?
8100 X-Cess?
8100 X-Cess gen 2?
8100 X-Clean?
300V?
Could you also share the blackstone report?
Thanks.
Old May 11, 2021 | 02:31 PM
My991's Avatar
My991
Originally Posted by pfbz;[url=[url
tel:17421587]17421587]Can[/url] you be specific on which Motul 5W40 you were using and had analyzed, as several have been mentioned here?
8100 X-Cess?
8100 X-Cess gen 2?
8100 X-Clean?
300V?
Thanks.
He said it was a 997…
For those stating that Amazon sends fake oil what’s your proof?
Old May 11, 2021 | 02:36 PM
AdamSanta85
8100 X-Cess?
8100 X-Cess gen 2?
8100 X-Clean?
300V?
Thanks.
8100 X-Cess, 991.1 C2S. Car has Gen2 5W40 Motul in it now but going to dump it for the M1 5W-50.
Ill try to dig it up, the viscosity numbers were below spec similar to what we see with M1 0W-40.
The car itself seems to run good, wear metals look ok, doesn't burn any oil or anything like that.
Old May 11, 2021 | 02:49 PM
My991's Avatar
My991
Any experience with M1 EP? It shows better results than standard M1 synthetic
Old May 11, 2021 | 02:52 PM
AdamSanta85
No I am not an oil expert at all, I have just been following @LexVan for a couple years, and looking at UOA's posted here and the M1 5W50 cars always look better.
Old May 11, 2021 | 03:32 PM
PhillyNate's Avatar
PhillyNate
My 987.2 has had nothing but Motul 5w 40 8100 X-cess for 6 years now. I have not had a UOA done but I can tell you 2 things. First and foremost my car doesn’t burn one drop of oil in between changes. Secondly, I have had zero drop off in performance in the same span of time. At least that’s what my @ss tells me. No mechanical issues either.
Old May 11, 2021 | 10:23 PM
smgkc's Avatar
smgkc
Petza914 posted this here, https://rennlist.com/forums/cayenne-...le-result.html I personally think if its Porsche approved and you warm up your engine before playing your good to go, but this thread made me think of the visual and thought it might help someone.
Old May 12, 2021 | 08:34 AM
Fullyield's Avatar
Fullyield
CAVEAT - I do not use DT 40 myself, but this is the old formula for DT 40 from 2017. Current formula for DT 40 has much higher Moly. Just an FYI for readers.
Old May 12, 2021 | 09:07 AM
AdamSanta85
991.1 C2S, Motul X-Cess 5W40
