Always wondered where is my 991.2 Diverter Valve? Me too
Old 02-13-2022, 03:14 PM
  #76
don16
don16's Avatar
Sorry to hear some didn't receive. I have a feeling these are sent from APR direct from distributor.
If this is the case, which I suspect it is, then tbf it's not there fault although communication sounds like it could have been better.
I also note APR USA website says stock due august so it's clearly a stock issue at APR HQ rather than this specific company.
Not yet fitted mine but quality seems outstanding so really excited to get them fitted next month or 2.
Old 02-14-2022, 08:05 PM
  #77
capiii
capiii's Avatar
Anybody know what an Indy would charge to install these while they are already in doing my plugs??
Old 02-14-2022, 08:16 PM
  #78
Tier1Terrier
Tier1Terrier's Avatar
Plugs don't require a bumper removal. Diverter valves do. So there isn't really any crossover in labor. My guess is that this is about a 2 hour labor job by an indy experienced with 991.2s. I've yet to do mine but it will probably take me all freakin day when I go to do it since I likely take my time and lots of pics/video.
Old 02-14-2022, 09:09 PM
  #79
Sarawnty
Sarawnty's Avatar
My wife gets mad at me every time she sees the car in this state :-)
The following 2 users liked this post by Sarawnty:
991_T (02-15-2022), doctj (07-02-2023)
Old 02-15-2022, 04:19 PM
  #80
Tier1Terrier
@Sarawnty Yeah, mine does too. I see you got the Flat Six DVs. May I ask what the wire thingy that seems appears to wrap around the DV is? Also, did you have to remove the pipes to install the DVs or was that not necessary?
Old 02-15-2022, 09:06 PM
  #81
Sarawnty
Sarawnty's Avatar
The wire is safety wire to keep the tube nipple from ever coming off the DV. The tube nipple simply slips on to the end of the DV. I doubt it would ever slip off but wanted added assurance that I wouldn’t have to take everything apart in the event that the tube nipple came off. I found it easier to remove the entire intercooler cage and intake plumbing to get at the DVs.
I have the FVD tune and found boost would dial back a few psi at peak. These seemed to solve that problem.
DR911s (05-09-2023), F355bob (02-15-2022)
Old 02-15-2022, 09:38 PM
  #82
F355bob
F355bob's Avatar
I have the same DV and the nipple can't come off because it has a lock on it when you install the nipple on the DV. To release it you have to get a small pick and get underneath the nipple to release the clip. It won't pull off no matter how hard you pull.
Sarawnty (02-15-2022)
Old 02-15-2022, 10:34 PM
  #83
Tier1Terrier
@F355bob So does the 90 degree nipple thingy ‘click’ into place when you pop onto the diverter valve? Asking for a friend.
Old 02-15-2022, 11:04 PM
  #84
F355bob
F355bob's Avatar
Yes
The following 2 users liked this post by F355bob:
991_T (02-16-2022), Tier1Terrier (02-15-2022)
Old 04-14-2022, 12:10 AM
  #85
Tier1Terrier
Originally Posted by Dark_horse
Changed mine out. I didn’t mess with the intercooler or the cage. Just removed one heat shield and I had more than enough space to change it out.
@Dark_horse I may be going a similar route. Im swapping out my cats and will looking to swap diverter valves when the cats are out of the car. Do you think that will make it much easier to install?
Old 04-14-2022, 02:54 AM
  #86
Dark_horse
Dark_horse's Avatar
It will be super easy with the cats out. It will just be staring you right in the face with the cats removed.
You can also see in my pictures how exposed it is with just one heat shield removed.
Old 04-16-2022, 12:46 AM
  #87
Tier1Terrier
you weren’t lying. Staring me right in the face once the cats came out. Turned out to be the easiest thing I’ve done since setting out to upgrade by cats.
Old 04-16-2022, 10:01 AM
  #88
Dark_horse
Dark_horse's Avatar
Always nice to have easy installs. Why can’t every mod be this easy!
Old 12-08-2022, 10:48 PM
  #89
Pandaa
Pandaa's Avatar
Does this make a nice old school JDM level of sound, or mostly just a preventative swap?
Old 12-08-2022, 11:30 PM
  #90
Tier1Terrier
Forgot to update this thread when I finished installing mine.
Quick Reply: Always wondered where is my 991.2 Diverter Valve? Me too
