Always wondered where is my 991.2 Diverter Valve? Me too
Old 02-19-2021, 12:49 AM
aft86
aft86's Avatar
Anyone know the correct direction in which the APR R1s should be installed? #1 or #2?
Old 02-19-2021, 12:58 AM
thesaintusa
thesaintusa's Avatar
Your dog recommends #2.
aft86 (02-19-2021)
Old 02-19-2021, 01:02 AM
aft86
aft86's Avatar
thanks. Yes, he was figuring it out with me haha. I figured the diaphragm pushes up that way, wanted to be certain.
Old 02-19-2021, 09:15 AM
polobai
polobai's Avatar
Received 1,125 Likes on 670 Posts
#2 looks correct but what hose is that (intake/inlet)? The best way to tell would be if you can post a pic of the valves showing the inside of the ports. The one sealed by the diaphragm goes to the pressure side.
Old 02-19-2021, 08:30 PM
Jack F
Jack F's Avatar
are the diameters of the male portions of the diverter valve the same? It look like #1 would be a loose fit and #2 would be a proper fit.
Old 02-19-2021, 09:01 PM
aft86
aft86's Avatar
Yes, both sides are the same diameter. On my photo it looks off but they're the same. After some more research as to how these work, the turbo air pushes the piston/diaphragm up and the air recirculates back into the intercooler in this direction:
It's snowing and cold here in the northeast but as soon as it gets a bit warmer I'm going to add these along with the do88 turbo inlets. I should've added these when I added the csf intercoolers.
Old 02-19-2021, 11:01 PM
polobai
polobai's Avatar
Gotcha-makes sense now. You are installing on a 991 turbo/turbo s.
aft86 (02-20-2021)
Old 02-21-2021, 12:27 AM
FlintGTS
FlintGTS's Avatar
Could a leaking diverter valve be the reason my GTS only sees 16 psi when I think it is supposed to reach 18 psi?
Old 10-13-2021, 11:56 PM
mrneef
mrneef's Avatar
Got a question on this topic. Hopefully someone can help.
I had the GoFast Diverters installed recently. Upon getting on WOT the car overboost to 30+ psi when target according to Cobb AP is 20psi from the stage 2 ots map. Butt dyno also felt the car wasn’t as engaging before install and felt “airing” out as the rpms were climbing.
I had the tial intercooler, tial ic inlets, tial turbo inlets installed during this as well.
is it most likely one of the lines got linked or damaged?
TIA
Old 10-15-2021, 12:20 AM
Jack F
Jack F's Avatar
TIA
30psi? Wow!
Old 10-26-2021, 03:27 AM
4 Point 0
4 Point 0's Avatar
Received 1,264 Likes on 669 Posts
I had mine replaced with TurboSmart ones.
For those asking why, the stock ones are rubbish. When we took mine out, just as a precaution, we tested the stock one and one had failed.
Stock ones start to open the more pressure. Whereas after market ones are held closed by more pressure. Read that again. After market ones are meant to be reverse, so when you increase boost, it doesn’t force them open, it holds them closed, so no boost leaks.
Soul Performance (10-26-2021)
Old 12-27-2021, 12:38 PM
Gonzalo38
Gonzalo38's Avatar
So if there's no boost leaks.... I guess there's an improvement in performance and car would respond faster. Can you confirm if this is true ?
Would there be any impacts on emissions ?
Old 01-18-2022, 06:23 AM
Dark_horse
Dark_horse's Avatar
Changed mine out. I didn’t mess with the intercooler or the cage. Just removed one heat shield and I had more than enough space to change it out.
The following 2 users liked this post by Dark_horse:
cutlass476 (03-05-2022), polobai (01-18-2022)
Old 01-18-2022, 06:44 AM
rubycaymanr
rubycaymanr's Avatar
Just bought a pair, this will make the install much easier....Thank you
Old 01-18-2022, 06:52 AM
don16
don16's Avatar
How has it failed? At what mileage? and what boost are you running?
Quick Reply: Always wondered where is my 991.2 Diverter Valve? Me too
