Fidelity Powertrain warranty
Great point - I actually do have it in writing but in the form of an email.
I guess I did take a bit of a chance by taking his word vs. confirming with Fidelity themselves. However, given he's sold 100's of these warranties for Porsche's, I figured it'd be a safe bet.
So, I do not think MJ’s general statement that the PT warranty covers the PDK addresses the narrower issue of “does the PT warranty cover a failed distance sensor located on the shift rods which is an electronic component located inside the transmission case”. This is important because the failure of this distance sensor accounts for about 90% of the PDK failures requiring a PDK swap @ cost of $20k +. I hope all of you are correct, and it does cover it.
I see nothing in the T&Cs to suggest that Platinum adds additional transmission related coverage where Gold or Power Train does not. In fact, there is little difference between Power Train and Gold in terms of transmission.
For me personally, if I decide to buy coverage, I think Gold will be sufficient. I do plan to contact my local Porsche SA to see what experiences they have had locally with Fidelity.
I requested a quote from MJ at Mossy, and have a copy of the T&Cs which he also sent along. There is really nothing to differentiate the Platinum in terms of what mechanical systems are covered vs. the Gold. It adds coverage for control module programming, diagnostics, related damage if caused by a covered breakdown, and fluids if required to address a covered breakdown. The rest of Platinum is non-vehicle stuff like towing, substitute transportation, trip interruption, etc.
However, the exclusion for the Platinum warranty is completely different. Platinum coverage "includes the POWERTRAIN and GOLD Coverage Plans plus ANY OTHER MECHANICAL BREAKDOWN except for those items listed in the section EXCLUSIONS FROM COVERAGE and subject to the LIMITS OF LIABILITY section."
The items excluded from the Platinum coverage at exclusion #15 which states:
"UNDER PLATINUM COVERAGE, ANY OF THE FOLLOWING PARTS: BRAKE LININGS, BRAKE DRUMS AND ROTORS, DISC BRAKE PADS, STANDARD MANUAL TRANSMISSION CLUTCH FRICTION DISC, PRESSURE PLATE, PILOT BEARING, THROW-OUT BEARING AND ARM, AIR BAGS, SOLAR POWERED DEVICES, GLASS, LENSES, SEALED BEAMS, BODY PARTS AND/OR PANELS, WEATHER STRIPPING, TRIM, MOLDINGS, LOCK CYLINDERS, TIRES, WHEELS, ALL BATTERIES EXCEPT HYBRID/EV/HYDROGEN HIGH VOLTAGE BATTERIES AS LISTED UNDER GOLD, LIGHT BULBS, UPHOLSTERY, PAINT, BRIGHT METAL, FREEZE PLUGS, FILTERS, HEATER AND RADIATOR HOSES, EXHAUST SYSTEM, CATALYTIC CONVERTER, SHOCK ABSORBERS, WORK SUCH AS FRONT-END ALIGNMENT OR WHEEL BALANCING (EXCEPT WHEN REQUIRED IN CONJUNCTION WITH A MECHANICAL BREAKDOWN), SAFETY RESTRAINT SYSTEMS, AUDIO/SECURITY OR OTHER SYSTEMS NOT FACTORY INSTALLED, OR VINYL AND CONVERTIBLE TOPS;"
So the Gold and PT warranties only provide coverage for components specifically listed. On the other hand, the Platinum warranty covers all components unless specifically excluded which is a big, big difference. Platinum covers the cause for ANY MECHANICAL BREAKDOWN except for components specifically listed in Exclusion 15 which are mostly wear and tear consumable items. So, the entire PDK transmission and transaxle is covered by the Platinum warranty (including the distance sensor in the transmission case) other than the clutch disc, pressure plate, pilot bearing and throw out bearing which are wear and tear items that are specifically excluded.
The following 4 users liked this post by Fullyield:
I think our posts crossed in cyber space. I disagree with your analysis and statement that the Platinum policy does not add additional transmission related coverage. I recommend that you read Exclusions # 14 in the T&C's which is the big difference between the Gold and PT warranties and the Platinum warranty. Per exclusion 14, the Gold and PT warranties ONLY cover those items specifically stated and included in the policy. So, a component is not covered under the Gold or PT warranty unless specifically mentioned which leads to the PDK distance sensor issue because it is not listed.
I am in a similar situation with warranty no my 991.2 expiring this year in September and I would love to keep my babied car with only 21K miles and get an extended warranty Options are trade in for another vehicle, possibly a 992 or cross shopping with a C8 which are second and third option respectively and much less favorable personally. Any suggestions on how to reach MJ from Mossy Motors or any other suggestions. Input very much appreciated
For us CPO goes, we are at the end of the road on Porsche warranties.
BGLeduc (01-13-2021)
i think what we all really want to know is if anyone has used Fidelity Powertrain only warranty to cover a PDK replacement. We know platinum does. Has anyone had Gold warranty cover PDK replacement?
Otherwise all this hypotheses will remain that.
The following 2 users liked this post by cclcal:
MkC2S (01-14-2021),
PatrickBateman (05-20-2022)
mjourdan@mossymotors.com. Be sure to mention “Rennlist”to get discount.
Bringing this back up to see if anyone can answer this. Currently have 2 years and 8 months left on platinum coverage and may do no coverage or powertrain only next as I haven't had a single claim in the 3+ years I've had the car/warranty.
Curious what you ended up doing, @AdamSanta85 and what the split was between Platinum and Powertrain (fine to PM me if more appropriate, and I know each car/case varies).
Not every vehicle qualifies for every tier of coverage, there are plenty of situations where a vehicle can only get Platinum or Gold coverage. Here are the only covered components for the PDK under the 2nd tier, gold plan.
Fidelity Gold:
TRANSMISSION: Oil pan; detent cable; kickdown link; throttle cable; vacuum modulator; transmission mounts, all internally lubricated parts contained within the transmission, transaxle and transfer case, plus the following: all internal fasteners, nuts and bolts; shift cover and forks; bell housing, components within the bell housing; torque converter; external valve bodies, control units and solenoids; seals and gaskets.
For quotes, questions, and example contracts. You can contact us at (855) 924-1333 or tgibson@highline-autos.com
Fidelity Gold:
Your place for distinguished automobiles, proud provider of Fidelity & Freedom Warranty extended warranties. Visit us at Highline-Autos.com
Official RECARO Automotive Retailer: www.highline-autos.com/product-category/recaro/
Highline Autos Magazine - Volume XXI, Issue 03 https://bit.ly/3wTsNzM
Fidelity Gold:
Fidelity Gold:
That's the rub, isn't it? The most common failure is the distance sensor. Don't see that listed. If you want to know the most common failures on aPDK the 997 forum has a great sticky on it, and how to perform the repair yourself.
997 forum guide to repairing PDK
The following 2 users liked this post by Upscale Audio:
Fullyield (05-22-2022),
Highline-Autos.com (05-23-2022)
