Endless brakepads
So, are these OK for 99% street/1% slow DE events? The dust on these OEM pads is driving me crazy. They also squeal from time to time.
Looking for low dust, good performance in what many here may consider mildly spirited to GT cruising. Some noise OK as a compromise.
Apologies to OP if this is too off topic for the thread.
Thanks to all of you
i will take my mistress from hibernation this weekend and pull the brakepads out to make messurments before ordering new ones. It seems like the most visely way.
Here in Sweden Endless pads are insanely high priced so i will order directly from a Japan dealer.
i will update this tread with my measurements and hopefully i get the right one’s
MX 72+ is the newer better version of MX72.
ME20 are far superior on track and are Endless lol on the street.
i want a little more now. Apparently in Europe they have ME25 which sound perfect for me.
if i can’t source ME25, the. The next track option is N35S, but these aren’t the best for street and are 95% track pads.
Anyone have a Europe source for ME25.?
The ME20 would be more than enough for most. I want a little more hard core, but still drive to the track.
Cheers
Cheers
Today my endless pads finally arrived from 🇯🇵 and i can now confirm that
EIP240 front
EIP215 rear
fits my 991.2 GTS-2017
i went for MX72+ on all four corners and hopefully they will work fine. Here in sweden we dont have so many high speed/ heavy braking tracks so hopefully this compound will work fine.
EIP240 front
EIP215 rear
The following 2 users liked this post by Harvest1969:
AdamSanta85 (04-08-2021),
thesaintusa (04-08-2021)
They didn't have rear pads for a long time but recently noticed rear pads are now widely available (with limited stock).
Check it out.
EIP240 front
EIP215 rear
EIP240 front
EIP215 rear
I finally have N35S and they are sensational at the track.
Never once did they show any sign of weakness.
I run them on the street as well, and they are fine. Just be mindful of the first brake application from dead cold, you may need to push a little harder . The slightest bit of warmth and they come on. And then the hotter they get, the better they perform.
I am a hard core track guy and these are epic. ME20 are enough for most. But when you want more, N35S deliver.
