Calibrating Parking Brake after new Rotors and Pads?
So I just changed out the rotors and pads on my 991.2 GTS with AP Racking J Hooks and DS2500. Got everything in and I'm trying to drive off and I can't. I hear the parking brake release, but the rear wheels barely move (and I stall). I saw when I removed the rear rotors that there was spinner wheel to adjust the shoes, but I also read that there's an electronic program to calibrate the parking brake. What do you guys think it is?
Did you run your electric parking brake back when doing the new brakes? If not, you probably will have to. Pull the rear wheel where the parking brake is located, separate the electrical plug that goes to the parking brake. You will see two prongs there. Using a 12v spare battery, energize the motor with two jumper wires. It will now run either forward or back. You want it to run back, so swap the leads if it goes in the other direction. Once you have it run back, you're done. Bolt the wheel back on and drive, the parking brake will self-adjust. If you don't have a spare 12v battery around in a motorcycle or lawn mower, etc., you can possible try a common 9v battery, it may have enough juice for the push (I have not done that as I always have 12v batteries around). You don't need a program, or a computer, it's very simple to do. DO NOT attempt to manually twist the spinner wheels, you stand a high probability of damaging the motor in the Parking Brake.
The following 4 users liked this post by drcollie:
Did you run your electric parking brake back when doing the new brakes? If not, you probably will have to. Pull the rear wheel where the parking brake is located, separate the electrical plug that goes to the parking brake. You will see two prongs there. Using a 12v spare battery, energize the motor with two jumper wires. It will not run either forward or back. You want it to run back, so swap the leads if it goes in the other direction. Once you have it run back, you're done. Bolt the wheel back on and drive, the parking brake will self-adjust. If you don't have a spare 12v battery around in a motorcycle or lawn mower, etc., you can possible try a common 9v battery, it may have enough juice for the push (I have not done that as I always have 12v batteries around). You don't need a program, or a computer, it's very simple to do. DO NOT attempt to manually twist the spinner wheels, you stand a high probability of damaging the motor in the Parking Brake.
So I think I did run the back to answer your question? Would I just have to reverse it again?
You just took it off PARK, so now you have to run the motor back all the way which is different than just disengaging the brake from the cabin. So yes, you need to run it back. It's really simply, will take you longer to jack the car and pull the wheel than run it back to its stop point.
You just took it off PARK, you have to run the motor back all the way which is different than just disengaging the brake from the cabin. So yes, you need to run it back. It's really simply, will take you longer to jack the car and pull the wheel than run it back to its stop point.
chandanYOGI (01-07-2021)
You are most welcome! Almost all cars that have electric parking brakes will experience this. Audi, VW, BMW, Porsche, etc. You will be told you must take it to the dealer or a shop with a speciality computer to run the parking brake back and they will charge you accordingly, at least an hour of shop time if not two. But now you see you can do these easily using this method.
The following 2 users liked this post by drcollie:
chandanYOGI (01-07-2021),
IrocMan (12-30-2020)
Clarification. If changing pads with parking brake off, do I need to reset parking brake?
if changing pads and rotors with parking brake off, do I need to reset parking brake?
Changed between track pads and street pads several times and zero issue. Just curious since park brake sits on inside of rotor and not engaging rotors.
thanks.
thanks.
Also, check out these vids on E-brake calibration. A bit more complex than just running the motor back to one extreme:
https://www.iscantech.com/2020/08/21...t-calibration/
I have that option on my icarsoft, but I've tried it many times and I always get an error message that says "Unable to complete function" or something like that. It measures the shoe gap just fine, though.
