Got a Garage Lift...love it
Old 12-18-2020, 06:09 PM
  #31
polobai
polobai's Avatar
Received 1,125 Likes on 670 Posts
Here is mine in my prior garage (prior to P car life) and current setup. Both ceilings are just under 10 ft tall.
Now
Also used for servicing.
Old 12-18-2020, 06:46 PM
  #32
minh
minh's Avatar
Originally Posted by One N Done
I have lift envy looking at all your pics... 3 bay garage, but 1 bay has the bikes, etc... Porsche and Tesla inside. Audi and Honda outside. Ceilings too low for a lift ☹.
I too am having lift envy. 12 foot ceiling. 2.5 car garage. high lift garage door opener. I should be good to go!
Old 12-18-2020, 07:20 PM
  #33
polobai
polobai's Avatar
Make it happen-more affordable than many think!
Old 12-19-2020, 11:30 AM
  #34
Stevelev
Stevelev's Avatar
Depending on the lift, the height of both cars plus 6” is enough ... when shopping for lifts, I went to take a look at one at a guys home - he had a touch under 10’ of garage height and had a lift with two sports cars.
Although I have almost 12’ of height, my garage limitation for a two post lift was due to a bulkhead where the posts were situated ...
Old 12-19-2020, 12:13 PM
  #35
rsabeebe
rsabeebe's Avatar
my ceilings were horribly low also. many large checks later and i have 12' where it matters. 20' single door also allows for tremendous access. miserable contractor experience with massive delays, but the end result will help me overlook the process.
i should have lifts in place by now, but they'll wait until the spring at this point.
KWP1911 (12-21-2020)
Old 12-19-2020, 02:59 PM
  #36
kevinthickey
kevinthickey's Avatar
Nope, the installer recommended I not do that in case I want to move it.
Originally Posted by SeymourButts
Looks great. Did you also have to bolt the posts into the floor?
SeymourButts (12-19-2020)
Old 12-19-2020, 03:00 PM
  #37
kevinthickey
That's classic we have the same set-up!
Originally Posted by Pin It
Wanna trade??
Old 12-19-2020, 03:03 PM
  #38
kevinthickey
Originally Posted by slimmn
Congrats!! Looks great. I was looking at the Atlas myself, specifically the 408-SL or Garage Pro 8000.
Any special requirement/cost for the shipping? And did you install it yourself?
I worked through an installer for everything. He purchased the lift and installed it for me. Lift with install was $3,200. Other cost was the garage door motor mounted on the side and garage door rails moved higher. Had a garage door company do that for me...i think the total cost for that was $1,200
slimmn (12-19-2020)
Old 12-19-2020, 03:05 PM
  #39
kevinthickey
Originally Posted by megatron991
What was the rough price including shipping/installation? I think the Bendpak I was looking at was around $4k? Just need to work some more magic to fill the spot on top
$3,200 installed. I think the Bendpak was $4,500 installed so I went with the cheaper option. No regrets and I have friends wo have this same lift with no issues.
Old 12-19-2020, 09:44 PM
  #40
Bob Morley
Bob Morley's Avatar
Default Reinforced cement floor?
Did you have to reinforce the cement concrete under the posts? Normal garage floors are only 2.5-3.0 inches.
Old 12-19-2020, 10:43 PM
  #41
pbon
pbon's Avatar
Not under a 4 post; yes under a 2 post unless the floor is 4” or more.
Old 12-20-2020, 01:37 PM
  #42
dngo
dngo's Avatar
My friends and I have put together maybe 5 lifts. It’s not terribly difficult, the heaviest part is the ramp with the hydraulic ram. Otherwise assembly is relatively straightforward. The hardest part is getting the shipment dropped off at a residence because most freight shippers want to offload somewhere there’s a loading dock.
Old 12-20-2020, 06:20 PM
  #43
white6speed
white6speed's Avatar
Is there a lift that will work with 2 911's with a 9' ceiling
Old 12-20-2020, 08:35 PM
  #44
pbon
pbon's Avatar
If you can borrow a truck and a trailer, the shipping depot will put the lift on the trailer for you. I have taken them off by myself. I take the packaging apart and unload piece by piece. Those rectangular HF furniture dollies or car wheel dollies can be used to help unload and move the parts. You will need a floor jack or two or an engine hoist. A strong friend is great if available.
Old 12-21-2020, 12:03 AM
  #45
polobai
polobai's Avatar
Its going to be super tight. You will probably need a lift that has manual locks that don’t need the rails to be raised to unlock. With air actuated locks, the lift needs to go up about 4-6 inches to disengage the locks...you won’t have that room. You can always section and raise the ceiling to make more room if the structure will allow it.
Quick Reply: Got a Garage Lift...love it
