Weird electrical issues
Old Dec 13, 2020 | 09:31 PM
CTDan's Avatar
CTDan
Default Weird electrical issues
I recently bought. 2014 C2 PDK. Just under 19k miles. Not a lot of service records, a few oil changes & that was about it. Clean car fax.
The first thing that happened was on the drive home from buying the car. (It was a long drive from Houston to Kansas City.) I stopped for dinner & then started the car to continue the trip... Pulling out onto a busy road in OK City the radio and all associated lights turned off and then back on again a second or two later. It was like the radio restarted itself.
The next weird thing was the passenger door wouldn’t open, like the door was locked, but I’m pretty sure it wasn’t. Trying the unlock didn’t work, & I had to reach over & pull the handle. This happened a second time, but using the unlock button worked this time.
Last night, after sitting for about 3 hours, the car wouldn’t start. It just kept saying that I needed to put my foot on the brake. Finally, I pressed the pedal much harder & the car started.
Then today, after a short drive & a 15 min shut down, the car started but I got all kinds of messages that cycled through on the dash.
My first guess is a voltage issue from a bad battery. I have a tester at work & will test it tomorrow, but I’m open to other suggestions if you have them.
Any help is appreciated.
Dan
Old Dec 13, 2020 | 09:40 PM
Catharpin's Avatar
Catharpin
Yikes, not a good intro, When was the last brake flush?
Old Dec 13, 2020 | 09:46 PM
dkhm3's Avatar
dkhm3
That sucks. Sorry to hear this.
Old Dec 13, 2020 | 09:48 PM
CTDan's Avatar
CTDan
I bought it from a dealer (high end, but not Porsche), & they performed a brake flush & oil change.
polobai's Avatar
polobai
My guess is battery also. Post a pic of the battery and the date code is stamped on the terminal. If it’s original it’s time to change it.
Old Dec 13, 2020 | 09:49 PM
Time4Porsche's Avatar
Time4Porsche
These cars seem finicky with batteries as they are going bad. I hope with a new battery these issues go away. Maybe a dealer or trusted Indy visit to replace battery if needed would be a good idea.
Old Dec 13, 2020 | 09:56 PM
G.I.G.'s Avatar
G.I.G.
Veteran: Coast Guard
I would start with the battery, then go from there. These cars can develop weird electrical gremlins when a battery is starting to go bad. If it's the original battery and/or it hasn't been kept on a battery tender when not in use, you could be due for a battery. If you do replace the battery, pay a little more for an AGM battery and keep it on a tender if you're not going to be driving the car for more than a week or so, especially in the colder winter months.
Good luck.
Old Dec 13, 2020 | 11:00 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Bad battery and bad brake light switch.
Old Dec 13, 2020 | 11:07 PM
Southbranch's Avatar
Southbranch
Make sure the battery cable clamps are not loose.
Old Dec 13, 2020 | 11:27 PM
Jack F's Avatar
Jack F
You could remove the negative terminal and positive and cleaned them with dedicated battery cable clamp cleaner. Then put on positive and negative. I’d problems persists,buy battery. Is there a date of manufacture on the battery?
Old Dec 14, 2020 | 11:09 AM
dflowerz's Avatar
dflowerz
I am in the middle of a similar problem with my 2017 911 C2s. Multiple error messages and car would not start. Had to get it towed to the dealer. Currently waiting to hear what is wrong this week. I put a new battery in mine which did not help but I agree that the battery is the first thing to check.
Old Dec 14, 2020 | 02:59 PM
CTDan's Avatar
CTDan
I tested the battery and it shows charge and retry.
I cant believe this car would need charged after driving it 1300 miles in the last week.
But usually my tester will show "fail" for a bad battery.
Hmm... I think I'll buy a new battery and see what happens.
**edit** the battery is dated 8/14, so I feel like it's time.
Old Dec 14, 2020 | 09:07 PM
CTDan's Avatar
CTDan
Swapped the battery with help from: https://rennlist.com/forums/991/1041...ement-diy.html
It was an easy job, but the thread made it easier... fingers crossed it all works as it should.
I didn’t use a tender but worked quickly. After the install I found that all of my radio stations are still programmed, which I would assume is a good sign...
Thanks for chiming in.
Dan
