991.2 Methanol injection install
#47
Did some more soldering and heatshrinking last night. I could have hooked up without a quick disconnect harness but I wanted to be able to unplug it if needed. Bought the 8 pin duetch harness on Amazon for $23 and wrapped in oem fabric tape.
Harness from Amazon
Harness from Amazon
AdamSanta85 (12-02-2020)
Mrlownloud (12-02-2020)
#51
WOW you are alot more optimistic than me! I honestly dont think it will give much more (if any) peak power, but I do think it will make a big difference in terms of reducing heatsoak and keeping the power up there on repeated runs or in the summer/hotter months.
polobai (12-02-2020)
#55
Maybe 50% is optimistic if you are near the limits of the stock turbos. You are at 30% now and if the meth allows timing you be restored that is now being pulled or lets you run another 2-3 psi if the turbos can handle that, you could be at 40%. 50% might take more than the turbos can flow. You can change them next....
I will be looking for a car over the next year or 2 or 3. Currently, I would be leaning towards a 991.1 Turbo but what you are doing with the regular model 991.2 is impressive and I suppose an S would do more. I’ll have to weigh the car and mod costs when the time comes. I run meth on a 99 BMW M3 with aftermarket turbo system and an 08 M3 that is naturally aspirated so it is likely to find its way onto my next car.
#57
@polobai awesome project and great documentation.
Probably a little late, but in case you need more room or want to move stuff around, just thought of this, you can remove the air inflator storage box and use that space for whatever.
#58
Chillywon (12-07-2020)
AlterZgo (02-05-2021)
