Adjustable Control Arms - Tarett vs BBI vs E-Motion vs Elephant Racing Comparison
I'm looking at changing some of my Elephant Racing Adjustable control arms and spherical bearing bars.
Whilst some of the Elephant racing bars have great adjustability, I am sick and tired of rattles, and noises. Its time to cure the worst one, which has been driving me nuts. The Front lower control arm, with the puck. The ball joint quite a bit of play in it, and rattles over bumps. It has done this from day one. You can actually move it up and down and make the noise when on the hoist. But over the last two years, there has been so many other niggling issues, I hadn't gotten around to fix this one. This thread is not about bagging Elephant Racing. They have some good stuff. Some things have better adjustability. But some things are out dated, and were more suited to older models.
They need to realise, that some things have changed sufficiently to demand a retool.
Tarett Cup control Arm
Introducing the Cup-Series lower control arms for your Porsche 996/997/986/987/981 & 991 (not GT4 or 991 GT3). Much more than just another billet replica of the GT3 arm; this design is superior to any other aluminum arm on the market.
For safety, the problematic 12mm ball joint design, used on both OEM and other aftermarket arms, has been completely redesigned for a fool proof, larger, significantly stronger and more reliable design that you can count on. The ball joint consists of a replaceable over sized precision grade Teflon lined monoball bushing. High misalignment bushings provide safe and bind free operation at any ride height.
Problematic YES. So this is one of my solutions.
Now E-Motion has a completely different bar that attaches to that.
E-Motion
Now these are very different to my Elephant racing ones that are adjustable on the other end of the bar. I'm unsure which to match with the Tarett above.
E-motion 3 bars
You can see where it attaches to there control arm. However it appears that there control arm does not have an adjustable castor puck, like the Elephant racing or Tarett one. This puck is essential for a Carrera GTS to run RS size front wheels. As you need to add a lot of Castor to more the 265/35/20 forward, to stop it rubbing when on full lock.
There are three bars in the rear I have not done as yet. Tossing up between E-motion and BBI. It appears to be the same bars just rebranded?
I think I need to work on my braking. I have seen a few of these, and some guys get the braking into 1.6G.
I don't know if its the anti-dive bars working, or if I am too mechanically sympathetic when pushing the brake pedal.
I don't usually see cars accelerate as quick as mine though. : ) Post your results.
E-Motion
E-motion 3 bars
You can't go wrong with anything from Dundon. From the looks of it, you have to use the Dundon E-motion parts together. I can see the puck design being a failure point in the Elephant Racing/Tarrett design; i.e. it can slip. So it looks like the E-Motion design chose to make that fixed/solid and they chose to make the caster adjustable by using shims on the tension arms. Very much like how camber is adjusted on race cars, using shims where the upper control arm mounts to the chassis.
That was my thoughts as well. The Tarett one talks about the problematic ball joint of others, which has been driving me nuts.
I may ask E-motion/Dundon how they got around that.
Those are great numbers except acceleration. Put your foot down man, you're on the track. No speed limits 🤣
Thats the about all it does at Barber. Cant accelerate like that out of the pitts. I would have to use launch control to get anything close to yours probably.
Dude, thank you so much. This is exactly what I need. I want the Dundon Underbody front. But I needed a big **** soloution. Its about god damn time.
@Tyler@APR Hook a brother up. Or is it @3DMetal I need these brackets for my GTS. Does the active wing still work under the Swan neck? I need to see a rear shot. Is it Dundon's swan neck. Details man.
I'm a little excited.
And P.S. Tyler, my GTS is still faster than your T.
