Coolant System fault
Old Nov 1, 2020 | 01:57 PM
jskenefick's Avatar
jskenefick
Default Coolant System fault
A warning message appeared on my 2015 GTS yesterday advising that there was a coolant system fault and the warning helpfully suggested that I "visit the workshop". The traditional gauge appears to be fixed at +/- 200F, while the digital gauge varied between 198F-235F. Sometimes it it was very erratic. I was a ways from home, so I watched it as best I could while I drove home. Never saw the digital over 235F and I don't think the traditional gauge moved at all.
I have to get the two recalls taken care of anyway, so I'll call the dealer tomorrow and take it in.
Any thoughts?
Old Nov 1, 2020 | 02:12 PM
LexVan's Avatar
LexVan
Change Over Valve.
Old Nov 1, 2020 | 05:59 PM
spiderv6's Avatar
spiderv6
Originally Posted by LexVan
Change Over Valve.
Maybe. Maybe not.
Originally Posted by jskenefick
Any thoughts?
There are a thousand posts on this topic if you search.
Old Nov 1, 2020 | 10:29 PM
Wolpertinger's Avatar
Wolpertinger
Although it's hard to tell what it is from this side of the keyboard, statistics do point towards a change over valve, as LexVan says. I had the same issue on my 2012 C2S, and it was a change over valve as well. It's a very common issue. I had one replaced under CPO warranty in April and haven't had any problems since.
Old Nov 2, 2020 | 02:07 PM
Dewinator's Avatar
Dewinator
I had a similar issue this spring and it was a changeover valve. They said something like 3 or 5 of them were broken (heater cov had previously died and been replaced).
Old Nov 2, 2020 | 03:52 PM
LexVan's Avatar
LexVan
Link one, and help the guy out.
Old Nov 3, 2020 | 06:56 PM
97supratt's Avatar
97supratt
Anyone have revised part numbers for the COV's?
Old Nov 18, 2020 | 12:16 PM
jskenefick's Avatar
jskenefick
Well, it was not a COV, It turned out that the vacuum pump needed to be replaced. Ended up getting the two recalls done, a new set of tires and a few other things as well. They had to order the pump, so it will hopefully be done today. I've spent the last week driving a 2021 Cayenne. As nice as it is, it only serves to confirm that I am not a fan of the SUV/Truck.
