PCM 3.1 Screen Image Uncentered
Old Oct 17, 2020 | 08:47 PM
2015TurboS's Avatar
2015TurboS
Default PCM 3.1 Screen Image Uncentered
Was driving and the image displayed on 3.1 PCM shows uncentered. I tried multiple times to reset PCM and it did not help. Any ideas how to solve?
Old Oct 18, 2020 | 12:12 PM
SConn's Avatar
SConn
Yikes that would make me nuts. I hope someone has a fix for you!
Old Oct 18, 2020 | 12:21 PM
Jack F's Avatar
Jack F
That would make we make to keep trying to peek around the corner. Is car under warranty?
Old Oct 18, 2020 | 12:25 PM
darylbowden's Avatar
darylbowden
When you say reset PCM, did you do a handover reset? I'd be almost certain that is a software glitch but if it were me, I would pull the PCM out, unplug it, clean the connections, and then after you put it all back perform a handover reset.
Old Oct 18, 2020 | 12:38 PM
Porsche_nuts's Avatar
Porsche_nuts
Maybe disconnect battery, wait about 20 seconds, and then reconnect?
Old Oct 18, 2020 | 12:43 PM
2015TurboS's Avatar
2015TurboS
Thanks for all the helpful comments. I was able to fix the issue earlier this morning. I found another thread on a similar issue, turns out the ribbon cable from the pcm to the display was not locked in after my CarPlay mod. Problem solved!
Old Jan 12, 2021 | 12:07 AM
smiles11's Avatar
smiles11
Old Nov 13, 2021 | 12:47 AM
BW369's Avatar
BW369
I have the exact same issue that popped up on my Cayenne S this morning, installed the iSudar CarPlay kit, and while driving the display shifted exactly as in the photo you posted. I ordered new ribbon cables from AliExpress and will try and install those new ones when they come in. 4th time is the charm I suppose
Old Dec 11, 2021 | 09:34 PM
ScottySta's Avatar
ScottySta
Folks - I have the same problem - but the Apple CarPlay screen was perfectly fine in the center.
Was it just the PCM screens (and Porsche logo on Boot) ? I've been searching for this for the last hour or so - I just installed today!
L
Old Dec 12, 2021 | 12:12 PM
Guards_Red_991's Avatar
Guards_Red_991
It looks like the PCM is trying to social distance from you mate...
Old Dec 12, 2021 | 12:20 PM
BW369's Avatar
BW369
L
yes, it would be the cables then. The Apple CarPlay screen will look centered but check if there’s a slight shift to the right or left (the curvature of the interface will give it away). The Porsche Logo and the PCM screen shift will be definitely more obvious. You will certainly have to reopen and reseat those cables.
Old Jan 23, 2022 | 06:10 AM
Darkpower's Avatar
Darkpower
The UI change is on PCM side, not really simple thing to do, have to recompile the UI do change the whole layout, check my post for the detailed project that I have been working on in past two years
Old Feb 24, 2022 | 12:29 PM
time4akshun's Avatar
time4akshun
Sorry for the post rehash. I have the same problem as the original poster only with a twist. My screen is panning right but RESOLVES ITSELF after about 30 minutes! Similar situation as others with a JoyeAuto CarPlay aftermarket install. Happy to check on ribbons but kinda weird that it fixes itself after 30 mins?
Old Feb 24, 2022 | 02:10 PM
asellus's Avatar
asellus
30 minutes is enough for it to warm up, metals to expand, and connections to be made slightly more secure.
Shot in the dark, but that'd be my first assumption. Loose cabling.
