2013 C2S CEL
I have a '13 Carrera S with 45k miles that I purchased almost a year and 4k miles ago. It runs beautifully and I've never noticed it ever running rough. It gets good gas mileage and after a recent oil change (by me) it doesn't look like it's burning/leaking any oil (pulled out almost 8 full quarts).
About a month ago I got a CEL P1530 "Camshaft Adjustment Bank 1" (Permanent) code. It was running fine so I reset it using an iCarSoft POR V2.0 scanner.
Last week I got 2 more CELs P0431 "Cat 1 Efficiency below threshold Bank 2" (Permanent) and P0305 "Cyl 5 Misfire Detected" (Pending).
I plotted the voltages of the oxygen sensors while idling on both banks and they seem pretty consistent between 0.62-0.72V although bank 2 seems to be consistently about 10% lower thank bank 1. I thought there were supposed to be four oxygen sensors but I only see the option of viewing the back end sensors.
The last owner installed Fabspeed headers and exhaust. I've heard that some people need to install O2 spacers (https://www.fabspeed.com/fabspeed-un...nverters-pair/) for P0431 codes but I'm worried that the cam adjustment and misfire might indicate something more serious. Maybe since the misfire is just pending it was just a one-off event that I wouldn't have seen if the cat code didn't trigger the CEL. Any advice is appreciated.
Thanks, JR
Thanks, JR
