BBS LM-R's for my 991.2 C4S w RAS + PASM
Wheel set just arrived and I weighed them each, if anyone was interested.
fronts 24.9 lbs
rears 28.2 lbs
Are these heavier than my OEM? I’m posting this as I’m researching
fronts 24.9 lbs
rears 28.2 lbs
Hey guys/gals, wheels installed! I love the look, and it defiantly looks different than stock! But,
Id love to get opinions on my wheel stretch, the rim edges protrude out further than the tire so no wheel protection from the tire. They might be flush, but it’s close.
Also the wheels are pooching out from the well. Also not much, but it’s in my head and I can’t unsee it now. Is this something a drop spring will fix?
Any comments appreciated
Zohr.com
I love these wheels
Any issues I should be aware of?
Zohr.com
I love these wheels
The following 2 users liked this post by granjour:
Kelvin Chan (10-23-2020),
tourenwagen (10-23-2020)
granjour (10-23-2020)
Zohr.com
I love these wheels
Zohr.com
I love these wheels
Hi,
I have the same 991.2 c4s as you with rear-wheel steering. Will the same set work on the rear-wheel steering version? And how frequent will the tire touching the car body? Did you find any optimum tilt angle to avoid the touching? And if I tilt the rear wheel will this damage the rear-wheel steering? I am so glad that I found this thread when search for LM-R wheels for my c4s. Thank you again for all your valuable information!
Best,
Hans
Best,
Hans
Hi,
Best,
Hans
Best,
Hans
Han’s, the wheels/tire kit fit perfect and do not rub with RAS (rear wheel steering*). I’m set up with factory alignment so I cannot comment if camber changes would rub.
I’m really happy with this custom look and factory drive/handling, best of both worlds 👍🏼
