Electrical help needed on 991.2 - USB ports
Removed the PCM (did a radio delete) on my 991.2 Carrera T. The ONLY downside I have found is that I lost power to the USB in the glove box and the USB under the center armrest. I assume these could be wired directly to some power source other than the PCM. Is this correct? Any suggestions on what would be the easiest way to go?
Thanks in advance. Any help would be greatly appreciated.
You'll need to drop the 12v to 5v if you're powering them directly. I assume the PCM components were providing this service, so you'll need a buck converter or something to wire to the USB pins or, better yet, remove the USB panel and replace it with a panel-mount 12v USB outlet that can provide higher amperage so your devices can quick-charge.
egrossman (09-14-2020)
Nothing I'd be worried about on a car driven with any sort of regularity.
You'll have a very minor parasitic drain on an always-powered USB port. Simple enough to pull it off ignition power instead, or go overboard with a relay setup if the cigarette outlet is always powered.
