First 911 - 991.1 C2
Mine is a C2S 7spd Manual, PSE, no sunroof, no rear wiper, extended leather, dual climate control and no other options.
mgmarsh39 (09-13-2020)
Phone mount doesn't look bad at all in the cabin...
Thanks!
Appreciate the picture. Does the phone get in the way of anything while on the mount where you've placed it? I was moving mine around to the different locations to get an idea of which mount I'd want and where to put it. Are you able to a case and the phone still cling to the mount?
Thanks!
Thanks!
Hope this helps!
mgmarsh39 (09-15-2020)
Installed my Rennline phone mount over on the drivers side by my knee. I felt that was the best placement for me. I'll give it a couple of weeks and may move it over to the passenger side. Didn't want to block the cup holder though (love my morning coffee).
So far it holds the phone great. Only issue I've ran into is the magnet on the inside of the case stopped my wireless charger from working. I used the bigger rectangular one. Maybe switching to the small circle magnet will help?
Got my KW HAS kit installed today. Will give it a couple hundred miles to settle then make some final adjustments/alignment. Also thinking about going 8mm front and 15mm rear spacers.
mgmarsh39 (10-20-2020)
Agreed on the ventilated seats, and funny enough the day I discovered how useful they were was the same day that I discovered that my engine cover struts were shot.
The KW HAS is a good addition too!
