Brake Fluid Level Park Vehicle Safely Message
Hi I am having an issue were my brake fluid level light has come and I am not sure why. I assumed it was the brake pads so I changed all the brake pads and sensors. I also bleed all the brakes and still, the message is on the dashboard. What else could be the issue or how can I reset the system? Thank you
It stands to reason that if that sensor is working properly, that if you changed your pads and sensors and bled your brakes, that the fluid level should be even lower than where you started, which would mean that warning would still be there. Or, am I wrong?
I also added new fluid as part of the brake bleeding process.
koala (08-26-2020)
Sounds like that sensor must be defective, then. Can't think of any other reason if you've done everything else 100% correctly, which it sounds like you have!
Unfortunately, I do not know the answer to that - hopefully, someone here does. My best guess is that it is integrated into the reservoir it's self and might require that whole part be replaced. I tried looking at the diagrams related to the brake system and nothing stands out to me as a standalone sensor specific to the brake fluid level.
This image below is from the 991 Service Manual. I've circled the plug/connection for the sensor.
Part #991-355-013-02. Costs about $65.
https://www.sunsetporscheparts.com/o...g2LWdhcw%3D%3D
