991.2 PSE Question on C2
Old Aug 15, 2020 | 05:26 PM
eilig's Avatar
eilig
Default 991.2 PSE Question on C2
So I'm deciding between two different 991.2 C2's, one has Sport Exhaust, other does not.
Question: When PSE is NOT actuated, does the exhaust sound essentially the same as car that does not have PSE?
Asked differently: Would a car w/o PSE sound same as one w/PSE that is not actuated?
For me it is tricky, as I actually like the looks better w/o it (i.e. one exhaust pipe on each side, instead of both in center of rear bumper).
Just want to make sure I have all info before I make final decision.
Thanks in advance for the info!
Old Aug 15, 2020 | 05:35 PM
stout's Avatar
stout
Probably the best single piece of media on this...
Old Aug 15, 2020 | 06:38 PM
eilig's Avatar
eilig
I just watched the video. So it seems that even when PSE is not actuated in the car with it, there is still a slightly deeper and louder sound outside the car than the car that doesn't have it. But probably this is not discernible inside the car at all.
Old Aug 15, 2020 | 06:52 PM
KWP1911's Avatar
KWP1911
Here's one on track with no PSE
Old Aug 15, 2020 | 07:14 PM
BlueNorther's Avatar
BlueNorther
I have a 991.2 GTS Coupe, so comes with PSE. I find there is a very noticeable difference between PSE off and on, in normal mode, and a huge difference between PSE off / normal mode versus PSE on and sport/sport+. And that is why I like it so much, it is switchable, and goes from drive to church on Sunday mode to hooligan. You won't care about the tailpipes. My car pretty much stays in sports+ with PSE on, once it's warmed up, unless it's raining.
Old Aug 16, 2020 | 04:30 PM
shockedcape's Avatar
shockedcape
Get the one with the sport exhaust. It's WELL worth it
Old Aug 16, 2020 | 10:03 PM
DOG ON's Avatar
DOG ON
After almost 2 years of ownership of my 991.1 C2, the only thing that I regret it not having is PSE. If the cars you're deciding between are equally equipped otherwise, the one with PSE is where I'd land.
Old Aug 16, 2020 | 10:30 PM
mrpat3l's Avatar
mrpat3l
I wanted PSE but settled for a non-pse 991.2 since the car checked all my other boxes. Installed a soul performance exhaust with high flow cats a few months after ownership, couldn't be happier.
I prefer the look of the quad tail pipes better.
Old Aug 16, 2020 | 10:35 PM
stout's Avatar
stout
^ To each their own, but my two cents:
  • I wouldn't let PSE or no PSE sway my decision between two nice 991.2s (assuming they aren't identical), or whether I'd buy a particular 991.2 if I liked everything else about it. Both systems are "fine," and can always be replaced with one of several aftermarket options.
  • I drove quite a few 991.2s with and without PSE (a dozen?) and then ordered two 991.2 Carreras in a row without PSE as I don't love its artificial pops & crackles or aesthetics. Yes, the standard exhaust is a bit quiet for my tastes at times, which has me wishing for 10-20% more voice (not to be confused with volume), but the car is hardly quiet. YMMV…
  • A friend bought a 991.2 Carrera T, and sometimes drives my 991.2 Carrera w/o PSE; he absolutely loves his T, but wishes it didn't have PSE. Fwiw, we both love (and have) "loud" sports cars...they just aren't our daily drivers.
Old Aug 17, 2020 | 12:16 AM
B Russ's Avatar
B Russ
Can you put Soul Cats on a Non Pse car
Old Aug 17, 2020 | 12:49 AM
spdracerut's Avatar
spdracerut
Soul does offer sport cats for the non-PSE exhaust as do Vektor, Fabspeed, AWE, and probably a couple others I'm missing.
911toR8's Avatar
911toR8
^ yes you can.
Also you can install PSE later on if needed, its not that difficult.
Old Aug 17, 2020 | 12:09 PM
Soul Performance's Avatar
Soul Performance
Basic Sponsor
You certainly can. The difference will be less dramatic than on cars with PSE as the valves open flow path on PSE is almost straight through. On non-PSE cars, the amount of turbo spool will be noticeable but the overall exhaust volume won't rise dramatically.
For OP's reference, here is a PSE car with Sport Cats:
Non-PSE Base model with Sport cats:
Alternatively for non-PSE cars - changing the rear exhaust alone to our Performance Exhaust will offer an incredible sound - on par with the volume level of a Sport Cat equipped PSE car.
-Mike
SOUL PERFORMANCE PRODUCTS
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Mike Spock - Marketing Director
mike@soulpp.com
SOUL In The Shop Instagram
Old Aug 18, 2020 | 10:00 AM
eilig's Avatar
eilig
When Sport Exhaust is not activated, does it sound the same as a car that does not have Sport Exhaust? Are there any differences in the tonal quality of the exhaust sound even when not activated, or does it basically sound same as car that doesn't have it?
Old Aug 18, 2020 | 08:43 PM
Phillip Berk's Avatar
Phillip Berk
Okay so from my personal experience, a base carrera with sport exhaust closed will be quieter than a car without sport exhaust, but with the exhaust open the PSE is noticeably deeper, louder, and overall more aggressive. when PSE is closed you can hear it, it sounds like a car with the valves closed, if you are used to valved exhausts you will know what I mean, it sounds like its ready to break free or open up, on the Base model without PSE it sounds a bit louder and deeper. on the S you have vacuum operated valves so the S onces the valves are open are def louder then PSE closed, but still not as loud as PSE with open valves. hope that helps
