991.1's come with the factory locks that match other bolts besides the pattern. This is the first I've heard it would be any different and been torquing to 118-120 all along (?)
Originally Posted by 97supratt
118 is correct and if you have wheel locks it’s less so be careful you don’t strip your wheel bolts.
Please could you elaborate on this? I have wheel lock bolts on my ‘17 991.2, 1 per wheel. Are these bolts not able to hold up to 118 ft lbs?
My experience is that the key or the lock can get stripped when being tightened or removed. Frankly, the last thing I wanted after a flat tire was a missing wheel key.
Ahhhh...the splines. Ok, I can see that happening. Thanks! That's probably what happened, but I'm still interested in @97supratt 's experience.
I stripped the hub by over tightening the wheel lock. From what I remember from experience, you tighten every lug nut or bolt and the last one you tighten is the lock. The torque spec should be less due to the fact that it’s only a lock.
