Removing wheel weight residue
Old Jul 23, 2020 | 06:06 PM
Cristophosphorus's Avatar
Cristophosphorus
Default Removing wheel weight residue
Had a pretty reputable indie shop install new tires recently. After washing the car, I noticed that there's a lot of glue/residue left over from the old wheel weights.
Did my shop screw up by not cleaning this off? And would Goo-Gone or a similar product work without damaging the wheel?
Old Jul 23, 2020 | 06:12 PM
BIGWORM's Avatar
BIGWORM
Go gone. Rubber eraser. Or just some soap and water on a rag should rub that off.
Old Jul 23, 2020 | 06:14 PM
dd356's Avatar
dd356
If not, put some wd 40 on it, and let it sit a while, it really melts/breaks down adhesive and you can wipe it off.
Old Jul 23, 2020 | 06:31 PM
Joec500's Avatar
Joec500
or get a paper towel soaked in rubbing alcohol and let it sit on there for a few minutes (10 mins) and check to see if you should leave it longer. Should come off easy after.
Old Jul 23, 2020 | 06:54 PM
quattroboy's Avatar
quattroboy
Use a plastic scraper (or old credit card) to remove the bulk adhesive, then apply 3M adhesive cleaner with a cloth rag to remove the residue.
Old Jul 23, 2020 | 07:21 PM
Jeahbladejeah's Avatar
Jeahbladejeah
Four serious responses. Each with different advice. Love it.
OP -- let us know how you go about it and whether it worked. I have some residue that I want to remove as well.
Old Jul 23, 2020 | 07:34 PM
Bemo's Avatar
Bemo
Go back to this "high end" shop, make them do it and then rebalance the wheels for good measure.
What I did to the local dealer after they started me off with the same mess, in addition to using silver weights on my black rims.
Old Jul 23, 2020 | 07:42 PM
Joec500's Avatar
Joec500
All super similar with just a different solvent
Old Jul 23, 2020 | 07:49 PM
Bxstr's Avatar
Bxstr
Carpro Tar remover works as well, or Stoners Tarminator.
Old Jul 23, 2020 | 10:12 PM
barncobob's Avatar
barncobob
WD40 works well
Old Jul 23, 2020 | 10:13 PM
bkrantz's Avatar
bkrantz
The best thing to remove this and other adhesives is (wait for it) 3M Adhesive Remover. Usually available at most local parts stores.
And the tire shop screwed up by being lazy.
Old Jul 23, 2020 | 10:43 PM
Southbranch's Avatar
Southbranch
Are those marks on the rim just dirt-deep, or did they use a screwdriver to pry off the old weights?
Old Jul 24, 2020 | 12:44 AM
X51's Avatar
X51
Same question as Southbranch. Those look like scratches in the wheel.
Old Jul 24, 2020 | 08:57 AM
LexVan's Avatar
LexVan
Wurth Citrus Degreaser.
Or denatured alcohol.
Old Jul 24, 2020 | 09:36 AM
AdamSanta85's Avatar
AdamSanta85
I have had good luck with 3M Adhesive Remover
Amazon Amazon
