3rd brake light bulb
Old Jul 10, 2020 | 05:39 AM
rubenhak's Avatar
rubenhak
Default 3rd brake light bulb
Anyone had replaced a broken bulb on the 3rd brake light? Can't seem to find which one is used.
Is it easy to access?
Old Jul 10, 2020 | 10:47 AM
Jim M.'s Avatar
Jim M.
All of the third brake lights are LED. I don't think you can replace a single LED.
Old Jul 10, 2020 | 11:36 AM
Porsche_nuts's Avatar
Porsche_nuts
You may have to replace the whole unit and not just a bulb. See link
https://www.6speedonline.com/forums/...t-removal.html
Old Jul 10, 2020 | 12:34 PM
Joec500's Avatar
Joec500
LED's don't really burn out. Are you getting the third brake light error while on the freeway and the wing deployed?
If that's the case your wiring is most likely torn causing that error. I see you're in SF, happy to help you if this is the problem. pretty easy fix.
Old Jul 10, 2020 | 03:37 PM
rubenhak's Avatar
rubenhak
Only one of the LEDs is not lighting up. It looks somewhat like the photo below. Definitely not caused by the torn wiring. Haven't seen errors. But i usually don't deploy the wing on my own, and don't even remember when was the list time I drove the car
I'm in the east bay. Appreciate your offer, but this is something i can probably do on my own. But, I'm comfortable with getting together and helping each other to fix broken things (my hvac blower stopped working again...)
Old Jul 10, 2020 | 03:39 PM
rubenhak's Avatar
rubenhak
Can it be opened? Cause in the end of the day it should be just a single LED bulb. I'm comfortable with soldering electrical components. The question is if it can be opened up.
Old Jul 10, 2020 | 07:55 PM
Joec500's Avatar
Joec500
anything can be opened, I remember pulling out third brake light when doing my ducktail install. It's all snap together (no screws) so disassembly maybe tough. I bet you can get a cheap one from a dismantler or ebay taken off a totaled car
Old Jul 10, 2020 | 08:34 PM
xford's Avatar
xford
Porsche Part # 99163118103 for a 991.1 (not sure if 991.2)
Old Jul 10, 2020 | 10:33 PM
rubenhak's Avatar
rubenhak
I got 991.1, but that part# also fits 918. I guess i'll go with that: https://www.porscheatlantaperimeterp...163118103.html
Old Jul 10, 2020 | 10:35 PM
rubenhak's Avatar
rubenhak
I was referring to opening in such a way, that can be closed up to original form
Old Jul 10, 2020 | 11:48 PM
xford's Avatar
xford
Many on here, including myself, like - get porsche parts dot com
Old Jul 11, 2020 | 07:47 PM
rubenhak's Avatar
rubenhak
I opened it up, but it broke to pieces Turns out its glued together and virtually impossible to separate the lamp halves. So ordering new one.
Old Jul 12, 2020 | 03:51 AM
Joec500's Avatar
Joec500
LOL I figure this would happen. At least it's not a ridiculously expensive part.
Old Jul 12, 2020 | 04:47 PM
rubenhak's Avatar
rubenhak
True. Ordered new one and a set of clear side markers.
